5 by 4-1/2 bolt pattern wheel? #903706
01/13/11 04:49 PM
01/13/11 04:49 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Are there any Chrysler cars with this bolt pattern?
It seems to me that 1968 and back Imperials were 5 by 4-1/2?
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903707
01/13/11 05:16 PM
01/13/11 05:16 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
All C-bodies were that size, so yes, some Chryslers.
I don't know the Imperial breakdown enough to comment completely, but I believe the 66-older Imps were 5x5. Lotsa subtle difference between Imps and Cs.
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903708
01/13/11 05:16 PM
01/13/11 05:16 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
If I get your question, and maybe it's a trick one, but the answere is: ALL other then A body cars were 5 bolt with a 4 1/2 spacing. IMPERIAL, CHRYSLER, (PLYMOUTH, DODGE) B and E but not A bodies. Not sure about sure about later ones (F, K etc.) A's had a 4 inch spacing.
Re: 5 by 4-1/2 bolt pattern wheel? [Re: DANA60] #903709
01/13/11 05:18 PM
01/13/11 05:18 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Some imperials had a larger bolt pattern than the 4 1/2.
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MoparforLife] #903710
01/13/11 05:28 PM
01/13/11 05:28 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
So I looked it up...
http://www.teufert.net/wheels/bolt-pat.htm
Chrysler/DeSoto - all full size RWD cars (exc. Imperial) '37-'89: 5 x 4 1/2
Imperial 54-66: 5 x 5 1/2
Imperial 67-71: 5 x 5
An exception missed on that webpage is the 81-83 Imp, which was 4 1/2. Don't see 72-76 listed.
Re: 5 by 4-1/2 bolt pattern wheel? [Re: DANA60] #903711
01/13/11 05:30 PM
01/13/11 05:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Just for future reference everything except trucks and maybe imperials were 5x4.5 starting with 1973 ...
Re: 5 by 4-1/2 bolt pattern wheel? [Re: JohnRR] #903712
01/13/11 07:06 PM
01/13/11 07:06 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Come on now! Every wheel I measure is 4-1/4, not 4-1/2. (68 Coronet R/T, 64 Belvedere, 62 Fury, 74 Valiant, 88 Chrysler) Except the older A-Body wheels from a 68 Valiant. A friend needs 4-1/2 and I'm attempting to locate some wheels for him.
I thought I could measure a wheel But????
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903713
01/13/11 08:00 PM
01/13/11 08:00 PM
Upper Midwest
Upper Midwest
Mopar wheels are 5 by 4 1/2 unless they are the 4 inch bolt pattern A body wheels or the larger Imperial wheels used for a few years that used the 5 on 5 inch bolt pattern. Of that era. No such thing as 4 1/4.
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903714
01/13/11 08:08 PM
01/13/11 08:08 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
5 on 4.25 was an Australian GM bolt pattern....you might just be measuring them incorrectly... You want to go from the outside edge of one hole, to the center of the opposite hole remember
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903715
01/13/11 08:08 PM
01/13/11 08:08 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Have you been measuring like this:
http://www.summitracing.com/expertadvice...chartsandguides
Re: 5 by 4-1/2 bolt pattern wheel? [Re: OzHemi] #903716
01/13/11 08:24 PM
01/13/11 08:24 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks OzHemi, and the rest of you who helped on this.
Today I learn how to measure a wheel.
So back to my search. The wheels I'm searching for measured 4-1/2 center to center. Does that make them 5"?
Would that be an Imperial wheel?
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903717
01/13/11 09:50 PM
01/13/11 09:50 PM
Milano, Italia
FK5 Offline
FK5  Offline
Milano, Italia
Why did you measure them center to center when the instructons say back of one lug to center of the other? You're better off going back and doing it right. That's better than having us guess.
What car is it for?
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903718
01/13/11 10:17 PM
01/13/11 10:17 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Could be 5 on 4.75 or 5 on 5 I suppose depending on just what size the holes are, best is to measure it the right way as mentioned. Figure on a steel wheel the holes will be just over 1/2" in diameter, so it would be another 1/4" or so than what you measured. If it was an aluminum wheel made for shank wheel nuts the holes will be somewhat larger.
Measuring it from edge to center takes that into account already.
Re: 5 by 4-1/2 bolt pattern wheel? [Re: MO_PA] #903719
01/13/11 10:19 PM
01/13/11 10:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
So then they're most likely chevy bolt pattern. 4.75".
