lm - 2 vs fast 170402 #902619
01/12/11 09:05 AM
01/12/11 09:05 AM
Wisconsin
1964maxwedge Offline OP
Wisconsin
I 'm trying to figure out which one is the best for me. All I need is air/fuel ratio no other out puts . Also do I need a dual channel ? The car is 1964 b body 505 with msd 6al2 .
thanks for your input
Re: lm - 2 vs fast 170402 [Re: 1964maxwedge] #902620
01/12/11 09:32 AM
01/12/11 09:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use a LM-1 and just changed it from one bank to the
other and once you determine the differential between
the banks you really dont even need to change banks...
I havent tried the FAST system so I cant help you
there.. but I would recommend the rpm logger for the
LM-1 if you go that direction
