Re: Another How fast will it go... [Re: DragDart360] #901787
01/11/11 04:36 PM
01/11/11 04:36 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
First couple times out it'll be in the 12's like that. I'd put 26" tires on it at the track to maximize gear (or find a 456 center section and keep the 28's) and shift it at 6800-7000 to see what it likes..might see a couple high 11 sec passes like that.
Its heavy, a 4-speed, and has light gearing and a smallish~ cam.
You would see solid 10's with an M1 intake, 600 lift and 456's and 200lb weight drop easy IMO
Also read/search anything member Big_Squeeze has said about getting those cars to hook
Re: Another How fast will it go... [Re: SRT6776] #901788
01/11/11 09:35 PM
01/11/11 09:35 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks for all the recommendations guys! Plans have now changed though as a 408 stroker kit was only 145 bucks more than the pistons, rods, rings, and bearings that I had already bought plus the balancing, so i sprung for it...looks like im going to be re-spec'ing the camshaft, but most of the rest of the combo will be staying the same
Was actually shooting for a high 11 with the 360, hopefully I can atleast hit a guranteed mid 11 with the 408
Re: Another How fast will it go... [Re: mshred] #901789
01/11/11 11:14 PM
01/11/11 11:14 PM
ill
dennismopar73 Offline
ill
12.08 -12.16
good luck
