Another How fast will it go...
#901767
01/10/11 10:54 PM
01/10/11 10:54 PM
Posts: 3,415 Toronto
mshred
Toronto
Here's the combo, what do you think? I know the downfalls in the combo for what I want to do with it, but as it sits, what do you guys predict?
360 smallblock chrysler stock stroke .030" over KB pistons 10.5:1 CR with 0.040" quench IMM prepped RHS iron heads flow peaks 271 at 550" on the int, 190 at 550" exh Bullet hydraulic roller cam 243/251 at .50 duration, lift is 562/562 on a 109 LSA with 4 degrees advance ground in on a 1.5 rocker (not sure if i should step up to the 1.6 and getting 600/600 out of it). Exh lobe is considering light nitrous use in the future as well Was told rpm range would be 1500-6200, but possibly higher?
Edelbrock RPM air gap port matched with a Holley 750HP on top 1-5/8" headers into a 3" exhaust with Borla race mufflers and x pipe
The car weighs 3400lbs with me in it and is getting a dana with 4.10 gears Car has a 28x12.5 ET street bias ply and has the full caltrac setup out back, with calvert 90/10's up front, 6cyl torsion bars and adjustable upper control arms
Transmission is a a chrysler 4 speed 2.66 first transmission with a centerforce dual friction clutch and a v-gate shifter with two step (hopefully will help with consistency some and not missing gears)...Im a pretty good driver and at the track the gas will be matted 110% of the time
lets hear it! hopefully my hopes for it are close to what it should run
Re: Another How fast will it go...
[Re: mshred]
#901768
01/11/11 12:12 AM
01/11/11 12:12 AM
Posts: 4,678 On the parachute mount
n20mstr
the weight is what concerns me, i would say at 3000lbs thats a 10 sec car, at 3400 id say 10.50-10.70
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#901769
01/11/11 12:21 AM
01/11/11 12:21 AM
Posts: 1,481 Outside
thedriver
Outside
11.70's NA
1973 challenger Dana. 4 speed. Low deck.
[Re: thedriver]
#901771
01/11/11 12:27 AM
01/11/11 12:27 AM
Quicktree
[Re: mshred]
#901773
01/11/11 12:32 AM
01/11/11 12:32 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Your weight is about 100 lbs lighter than a Challenger I had and with a much more tame 360, I went 11.70, but I had 4.56 gear, 28x10.5 slicks, auto, 3500 converter, home ported stock heads, .540 flat solid, 9:1 compression.
If you can row those gears, I would think 11.4's.
[Re: TheOtherDodge]
#901774
01/11/11 12:38 AM
01/11/11 12:38 AM
Posts: 7,506 Az
Crizila
Az
12.000000's on a good day.
Fastest 300
[Re: Crizila]
#901775
01/11/11 12:50 AM
01/11/11 12:50 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
4 speed...
how good can you shift?
and getting the car to launch without bogging it.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#901776
01/11/11 12:53 AM
01/11/11 12:53 AM
mshred
Toronto
4 speed...
I can hit the gears pretty good, and the v-gate is there to try and eliminate missed shifts
I know my gear ratio is going to kill me though....it being a stickshift with only 4.10's, im hoping if i launch high enough it won't bog, but Im not sure...not many stick combos to compare too that are mopar
Id go to a higher numerical gear, but this car sees alot of street use and the 4.10's with a 28" tire are already pushing it for the highway
what do ya think?
[Re: mshred]
#901777
01/11/11 01:02 AM
01/11/11 01:02 AM
Triple Threat
Renton Washington
The motor is gonna make enough power to push the car well into the 11's. Whether or not you can do you job will be the biggest factor.
[Re: Streetwize]
#901780
01/11/11 10:36 AM
01/11/11 10:36 AM
mshred
Toronto
I'm thinking you could go easy 11.40's if it hooks, I ran 11.70's all night long with a 4 speed a-body with a W2 340 isky solid.....30 years ago.
Cam spec's look good for what you are doing, I like the 1.6 rockers.
my combo faster than a W2 combo? not questioning, just surprises me...How high were you spinning that 340 with the solid?
A member here has offerred to shim my hydraulic lifters in combination with a spring using about 150 open seat pressure so that i can rev up to 7k if needed
[Re: mshred]
#901781
01/11/11 10:47 AM
01/11/11 10:47 AM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Spun it 7200, eventually 7800 going to 4.56 gears....big block boyz HATED me back then I doubt my old first get W2's flowed much better than your RHS's, I was barely 18 and all I did was a bowl clean up and VJ on them. I eventually got them worked to flow around 290. When I detuned it to my daily work car it still ran high 11's switching to 3.91's and an ultradyne hydraulic 231/239 flat tappet. your ET is going to be in the 60'....if you get a 360 to hook just right you just row it through and she'll et. Didn't understand your open/seat comment...did you mean 150 on the seat?
[Re: Streetwize]
#901782
01/11/11 10:49 AM
01/11/11 10:49 AM
mshred
Toronto
cool...yes I meant 150 on the seat
please keep the predictions coming guys!
[Re: mshred]
#901783
01/11/11 12:05 PM
01/11/11 12:05 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
You don't need to shim the lifters...run the heads they way you get them and run the lifters untouched. Run 10w40 oil and let it eat. I've run hyd. rollers with our RHS heads up to 7000rpm and still not had any lifter pump. Brian
Brian Hafliger
[Re: dirty magnum]
#901786
01/11/11 03:26 PM
01/11/11 03:26 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
I think it should go 11.50 or better pretty easy. You weigh 500 more than mine and have enough power there to at least run a tenth better. Check my sig.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
