How to add front frame rail braces #898562
01/07/11 12:12 PM
01/07/11 12:12 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
I have a Duster with a 10PT and I was wondering about adding the front frame rail braces. I've seen some where there are flat plates bolted to the firewall and the tubing gets welded to that or the tubing goes straight thru the firewall and gets tied-in to the pillars. I have no trouble going through the firewall but I'm unsure as to how to locate the holes so I'm not butchering up the car.
The previous owner had chopped a couple holes out of the firewall to get to the tranny mount bolts (A-body 440 with midplate) which I have since patched. The rest of the firewall is untouched.
Re: How to add front frame rail braces [Re: Mofopar] #898563
01/07/11 01:05 PM
01/07/11 01:05 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
The front frame rail support bars should extend into the car and weld to the front down tubes. Preferably near the junction with the dash bar and the door X bar (if installed).
Re: How to add front frame rail braces [Re: ProStDodge] #898564
01/07/11 02:36 PM
01/07/11 02:36 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Thanks for the sketch. Any tips on locating the holes through the firewall? (I'm obviously a noob at this )
Re: How to add front frame rail braces [Re: Mofopar] #898565
01/08/11 11:25 AM
01/08/11 11:25 AM
Spring City , Pa.
SIKPUP Offline
SIKPUP  Offline
Spring City , Pa.
Stay away from your freash air inlets , go under them , not through !
SIKPUP
