Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898521
01/07/11 10:20 PM
01/07/11 10:20 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Of the ones I've seen start to go flat the top of the lobes had a pitted, cratered surface. This leads me to believe there was a problem with the cam itself, as if there was porosity in the core, and the lobe wore down to the porosity.
Re: 6 lobes off a camshaft?!? [Re: Sixpak] #898522
01/07/11 10:36 PM
01/07/11 10:36 PM
ill
dennismopar73 Offline
ill
i will agree i believe the cam was most likley bad
i too had a 590 m p cam take off lobes as well
mine was older version ,, i know know they had issues then sure they still do
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898523
01/07/11 10:51 PM
01/07/11 10:51 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
I had the same problem a few years back with a MP 557 from ( actually two of them ) problem was spring pressure were all over the place. My fault for not checking new parts.
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: 6 lobes off a camshaft?!? [Re: 64Post] #898524
01/07/11 11:36 PM
01/07/11 11:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Roller lifters come apart too, albeit not at break-in.
Solids take a bad rap from improper break-in/installation. This is just another case of improper break-in (likely too much spring pressure over the nose).
I'd add EDM lifters (in addition to pulling the inner spring) to the rebuild next time (assuming it gets rebuilt).
The 2 things that come to my mind are not removing the inner springs and DIRT ( lifters not rotating ).
Fastest 300
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898525
01/07/11 11:56 PM
01/07/11 11:56 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
also 1.6 roller rockers will smoke cams also on break in
MOPAR OR NO CAR
Re: 6 lobes off a camshaft?!? [Re: Thumperdart] #898526
01/08/11 12:28 AM
01/08/11 12:28 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I had a early 90's 509 MP cam that wiped a lobe - sent it back and it was tested and DID have soft metal ....
you going to bring that Charger to eddyville this year ?
Re: 6 lobes off a camshaft?!? [Re: 493_DART] #898527
01/08/11 11:08 AM
01/08/11 11:08 AM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
RE: 493_DART
Yup we will be bringing that up cept it is a 71 Satellite. We ran it a few times last year but had some wiring troubles hoping to get her back solid this year. We only have three drag cars to work on lol. You know my uncle Tim Jackson I believe I saw you there while he was talkin to ya.
