Page 10 of 13 1 2 8 9 10 11 12 13
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896953
12/14/11 09:47 AM
12/14/11 09:47 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Here is a picture of the engine compartment. I've been installing fluids removed the thermostat per several recomendations from fellow members. I Need to install wires some vac lines and the steering column, then I should be ready to light it up..
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896954
12/14/11 04:14 PM
12/14/11 04:14 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Looking great! But, why did you remove the thermostat?
Re: My 1973 Cuda Lemontwist [Re: dmoore] #896955
12/14/11 07:49 PM
12/14/11 07:49 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks. Several members have commented on taking out the thermostat because of pressure build up at startup. A Friend on mine had his 68 charger blow a hose off during initial startup and hot water all over his fresh black paint. I also wonder how they got around this in the factory but its an easy removal and replacement specially since I will just use water to comfirm for leaks.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896956
12/14/11 08:01 PM
12/14/11 08:01 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Small issues keep coming up, spotted a leak on my steering box today. It was rebuilt in August so they said to bring it back in and it should be an easy fix. Just a pain but do not want to wait and pull it apart later. Less to do after startup.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896957
12/14/11 10:10 PM
12/14/11 10:10 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Looks like its coming along nicely! Keep up the great work!
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896958
12/15/11 12:32 PM
12/15/11 12:32 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Car looks awesome and that garage is going to be nice.
65 Barracuda
70 Challenger
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896959
12/20/11 06:10 AM
12/20/11 06:10 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Took the steering box back in to Red Head Steering they replaced the seal. Didnt see anything wrong with the seal but thought the butter lube may have had some separation from sitting. The unit is ready to go back in.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896960
01/23/12 02:11 PM
01/23/12 02:11 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Well I installed the seats and column last week. It looks really nice having them in the car. The Seats look great are very comfortable Thanks Bill Edwards and slide well on the rebuilt tracks. Still working out some wiring issues with the column wiring and want to get the battery installed this week and check out as much as I can before I fire it up.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896961
01/23/12 02:17 PM
01/23/12 02:17 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I will install the console tonight door panels tomorrow and this should just about finish the interior.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896962
01/23/12 02:20 PM
01/23/12 02:20 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Looking forward to hearing that motor purrrrr.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896963
01/24/12 12:30 AM
01/24/12 12:30 AM
dmoore Offline
dmoore  Offline
Uhhhhh yeah!!
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896964
01/30/12 05:42 PM
01/30/12 05:42 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Had an real exciting weekend working on the car. The wife was out of town so i spent alot of time with my mistress. Finished putting in the fluids, and installed a test battery just to check out all the electrical. Still have some issues under the dash to work out. For the most part all lights work except for the dash guages and I still need to work up under the dash and might need to remove the seats for better access...
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896965
01/30/12 05:52 PM
01/30/12 05:52 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Saturday morning I went out and got everything set up to get ready to fire up the motor. Everything looked sweet under the hood no obvious leaks or concerns and it was time to get that baby started up. A good friend of mine that has been assisting me along with this project Charlie (70Mopes) showed up to give me a hand. His help along the way has been greatly appreciated....
He looked everything over and we started priming the motor. We put an oil pressure guage on it and it showed 80 PSI while priming.
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896966
01/30/12 06:01 PM
01/30/12 06:01 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Here is a short little video I posted on you tube of the event about 25 minutes or so after the initial fire up. We only had a few small issues 1 minor fuel leak at the thermoquad and also a minor vacumn leak at the back of the carb(I put in the wrong gasket). Stock Exhaust sounds sweeet !!! Time for a Cigar
http://youtu.be/b3wrJbT2nw4
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896967
01/30/12 10:05 PM
01/30/12 10:05 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
Re: My 1973 Cuda Lemontwist [Re: UCUDANT] #896968
01/30/12 11:35 PM
01/30/12 11:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Great job...you should be proud. It's taken a lot of work to get it to this point. It looks and sounds great!
Re: My 1973 Cuda Lemontwist [Re: burdar] #896969
02/04/12 12:32 PM
02/04/12 12:32 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Took out the Cuda for a short drive yesterday. It was a blast getting that car out on the road. Still missing the front and rear glass so it was a little windy. Put about 6-7 miles on it. Drive straight shifts good, Carb works well even the secondaries, the rings should should be well seated. The theory I use is dont baby it and dont beat!
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: 19cuda73] #896970
02/04/12 12:41 PM
02/04/12 12:41 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Need to get the mopar battery ordered and installed I think its a yellow cap top. I did get the Cuda emblem installed and some more decals on the door and in the trunk installed. May wait until it warms up some to do the Stock decals on the body...
1972 Corvette
Re: My 1973 Cuda Lemontwist [Re: burdar] #896971
02/04/12 09:34 PM
02/04/12 09:34 PM
Virginia Beach, VA
71ChallengerSE Offline
Virginia Beach, VA
The intake with the 71 date would not be correct for your car. Your intake should have a 72 date on it and use the newer style choke.
I think my October 72 built 318 has a late Sept. 72 date. The intake wasn't sitting around long before it was installed on an engine.
They used whatever the had lying around or dug up at the factory. That's why 71 dated 340s ended up in 73 cars
Re: My 1973 Cuda Lemontwist [Re: 71ChallengerSE] #896972
02/08/12 09:36 PM
02/08/12 09:36 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I Swapped out the wheels yesterday decided to go with the magnums They really make the car. Still working out the issues on the electrical but the motor sounds sweet. I shared it on You tube but you need to open the link with mozilla http://www.youtube.com/watch?v=b3wrJbT2nw4&feature=youtu.be
1972 Corvette
