Re: My 1973 Cuda Lemontwist
[Re: 19cuda73]
#896794
01/19/11 03:52 PM
01/19/11 03:52 PM
Posts: 1,300 Washington
19cuda73
Washington
Replacement fender fitted (or not) to the door ended up buying an aftermarket which turned out to be another bunch of rework after the car was painted. I will show pictures later of that rework later.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: 19cuda73]
#896796
01/19/11 03:54 PM
01/19/11 03:54 PM
19cuda73
Washington
Drivers side fit realy nice but this was the original fender very little rust
[Re: 19cuda73]
#896800
01/19/11 04:03 PM
01/19/11 04:03 PM
19cuda73
Washington
Hood to drivers Fender Nice gaps. OE at it best
[Re: 19cuda73]
#896801
01/19/11 04:04 PM
01/19/11 04:04 PM
19cuda73
Washington
Love the painted pin striping.
[Re: 19cuda73]
#896802
01/20/11 06:19 PM
01/20/11 06:19 PM
19cuda73
Washington
Sent it out for Blast, body work and Paint. Show Quality Restoration in Longview. Great shop.The guy came to the house picked it up in an enclosed trailer, did the work and delivered it the same way. Took about 4months.
[Re: 19cuda73]
#896807
01/20/11 06:31 PM
01/20/11 06:31 PM
19cuda73
Washington
At Home ready for the build.
[Re: dmoore]
#896809
01/21/11 03:12 PM
01/21/11 03:12 PM
19cuda73
Washington
Thanks Dave, One thing I will do on my next car is get as much done ahead of time while the car is out for paint. Lessons learned.
[Re: 19cuda73]
#896810
01/21/11 03:29 PM
01/21/11 03:29 PM
Posts: 7,382 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I don't remember you saying what your doing for a headliner. I'm pretty sure the 73 Cuda's used the same Yorkshire material(looks like corduroy) that the 73-74 Challengers did. It's definatly more expensive then the perforated style(used up through 72)but if your going for a stock look, it would be nice to use the right material. I got mine from Dante. Are you going to black out the rad support? There is a picture of a 72 Cuda on Cuda-Challenger.com that shows the factory spray pattern perfectly. Let me know if you want me to look for it. Keep the pics coming.
[Re: dmoore]
#896811
01/21/11 04:46 PM
01/21/11 04:46 PM
19cuda73
Washington
The Passenger front fender was an after market and was replaced at the paint shop. AMD hasn't quite perfected the fitment to the door yet. The only bad thing was that it got painted prior to working out the proper fit. Paint shop was real good they reshot the fender after Mopes70 (Charlie) cured the fitment issues.
[Re: burdar]
#896812
01/21/11 04:58 PM
01/21/11 04:58 PM
19cuda73
Washington
Head Liner is installed. It was my first. Just took my time followed the instruction from Resto Rick. worked great..
