Where does this Vacuum Hose Go? #89578
07/16/08 08:00 PM
07/16/08 08:00 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Hey Guys,
On my friend's 1970 440-4 Motor, I noticed that this vacuum hose at the back of the intake manifold is not hooked up to go anywhere (nor is the end plugged). The larger hose in the picture goes to the Power Brake Booster, but this one was just resting there on the intake manifold.
Anyone know what the purpose of this particular vacuum hose is and where it needs to go(or should be it plugged?).
Also, one related question -- would having this hose there unhooked like this, take performance away from the Power Brake Booster?
Thanks a lot guys for any tips!
-Stan
Re: Where does this Vacuum Hose Go? [Re: stan1970] #89579
07/16/08 08:34 PM
07/16/08 08:34 PM
Franksville, WI
g-man70 Offline
g-man70  Offline
Franksville, WI
stock air cleaner? just a guess.. also, I don't think it would impact the brakes if it's not hooked up to anything.
Re: Where does this Vacuum Hose Go? [Re: g-man70] #89580
07/16/08 08:46 PM
07/16/08 08:46 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not connected it is a vacuum leak and can cause the engine to run lean. It may take some vacuum away from the brakes, just depends on how strong the signal was before and the inside diameter of the unconnected line.
The line probbably goes to the stock air cleaners thermostat control that closes the air cleaner door when cold.
Re: Where does this Vacuum Hose Go? [Re: 451Mopar] #89581
07/16/08 08:56 PM
07/16/08 08:56 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Definitely remove the hose and cap off the port if it's not being used.
Re: Where does this Vacuum Hose Go? [Re: g-man70] #89582
07/16/08 10:33 PM
07/16/08 10:33 PM
if you have a stock air cleaner, it would go to the vacuum switch mount in the base of the air cleaner. the other side of the vacuum switch goes to the vacuum actuator on the aircleaner snout to divert the carb air from the snout to the heated air intake manifold mounted on the exhaust manifold.
if you dont have that setup, just cap it off. a vacuum leak will hurt your vacuum signal to the carb and hurt your performance (youll run lean)
Re: Where does this Vacuum Hose Go? #89583
07/16/08 10:38 PM
07/16/08 10:38 PM
Andrewh Offline
Andrewh  Offline
actually that seems more likely for heater or a/c vacuum.
Or at least you are missing that hose if it isn't there. Something has to go back into the passenger compartment for that system.
Re: Where does this Vacuum Hose Go? [Re: stan1970] #89584
07/16/08 10:50 PM
07/16/08 10:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
What year and body style is the engine in ?
I assume the engine isn't original to the car it's in
Re: Where does this Vacuum Hose Go? [Re: g-man70] #89585
07/17/08 12:31 AM
07/17/08 12:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That nipple is for vacuum to an A/C switch, if the car doesn't have A/C but still has P.B. it should have a single large port style nipple...
Re: Where does this Vacuum Hose Go? [Re: 1_WILD_RT] #89586
07/17/08 07:48 AM
07/17/08 07:48 AM
it doesnt look long enough to reach anywhere close to where an ac vacuum switch would be.
Re: Where does this Vacuum Hose Go? [Re: gtx6970] #89587
07/17/08 09:31 AM
07/17/08 09:31 AM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Hi. Thanks guys for the tips.
This is in a '70 Challenger - 440 A/T car, but non-AC. I am not sure if this is the original motor for it, but I'll check out the VIN this weekend on it.
Thanks again.
--Stan
Re: Where does this Vacuum Hose Go? [Re: stan1970] #89588
07/17/08 09:33 AM
07/17/08 09:33 AM
Andrewh Offline
Andrewh  Offline
well it doesn't have to be an a/c car. My heater only car had one vacuum hose that went into the car for the vacuum actuated switch for defrost to heat.
Re: Where does this Vacuum Hose Go? [Re: Andrewh] #89589
07/17/08 10:19 AM
07/17/08 10:19 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
The vacuum line should enter the firewall just below the blower motor on the passenger side. See my pic of my 71 roadrunner. The 70 Challenger should only have one hose entering the firewall since the heater valve is controlled by a sliding wire. The firewall layout should be similiar.
Ron
