didnt find it... but from an older crane book, heres what i found: h-232/3360-6 is a hydraulic with 304 adv, 232 at 50 and .504 lift,`h` meaning hydraulic BUT
f-278/4002-8 and f-288/4134-8 are 7800 and 8200 rpm SOLIDS one at 600 lift and the other at 620 lift, so f-284 must be in between.just my reasonning. maybe it doesnt make any sense at all! all cams listed are smallblocks btw. f-278/4002-8 and f-288/4134-6 are also bigblock cams with same specs as the small blocks, using different part numbers. probably same lobes between sb and bb.
