best way to replace a headlight switch #892511
12/31/10 02:49 PM
12/31/10 02:49 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
I belive it's called a rheastat? This is in a 1967 Plymouth Satellite.
My on/off works, but the dimming feature is worn out. Can I just get one at the auto parts store and put my knob on it? or is there a certain part I need?
Thanks guys-
Gary
Re: best way to replace a headlight switch [Re: StealthWedge67] #892512
12/31/10 02:54 PM
12/31/10 02:54 PM
scratchnfotraction Offline
yes,just repalce the switch with a new one from napa..ect
your knob will come out and go in the other one
did it on my 68 dart and my truck
little button on top of switch you mash down and pull the knob/stick out
unbolt from dash and unplug it
plug in new switch,mount back in dash,push your knob/stick back in the switch...IIRC you dont need to mash the button going back in the switch
look it up for your yr/model car
Re: best way to replace a headlight switch [Re: scratchnfotraction] #892513
12/31/10 04:01 PM
12/31/10 04:01 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Here's a picture of a generic switch and the knob/ shaft. Put the headlight switch ON before you push the button
Re: best way to replace a headlight switch [Re: StealthWedge67] #892514
12/31/10 09:10 PM
12/31/10 09:10 PM
Might see if you can access the rheostat coil & see if it has an open or just needs cleaning where the tang rides across it. If not, what Yancy said & a bit of dielectric grease on the terminals helps
