Re: Edelbrock carb. problem HELP!!!!
[Re: MoparTod]
#89175
07/15/08 09:21 PM
07/15/08 09:21 PM
RapidRobert
after the car has sat for a week (1)see if a stream squirts out of the AP when you move the throttle (without touching the starter) (2) take the top off & see if your gas has evaporated or (3) disappeared into a pinhole leak.It's gotta be going somewhere.
[Re: MoparTod]
#89177
07/16/08 03:05 PM
07/16/08 03:05 PM
Posts: 15,487 Florida
scratchnfotraction
the gas is evaporating from the bowl vent.eddys are getting famos for this you can just add a small elec fuel pump back at the tank and prime the carb before cranking it over,this will fill the bowl and fire it right off every time some times the fuel will drain back to the tank also,so cranking will be more till the line,pump,carb are full then it will start after sitting for a week you can just get a dish soap bottle with a little gas in it and prime the carb through the vent tube then start it tired of the eddy yet? I went back to a Q-jet on my teen cause the eddy was doing this all the time the cheap gas is no help either IMO
[Re: MoparTod]
#89179
07/16/08 03:22 PM
07/16/08 03:22 PM
scratchnfotraction
yea just one of the little cheap inline banger pumps you can run both with no prob,flip the switch on and give it a second then hit the key and you can allways turn the elec pump back off after its running,the stock pump will still pull fuel through it most wimpy stock pumps could use the help IMO keeps from opening the hood to prime and jump start it
[Re: DarrenS]
#89182
07/16/08 03:47 PM
07/16/08 03:47 PM
scratchnfotraction
you are correct it very well could be a weak fuel pump could have pin holes some where in the line also letting it suck air do you have a clear fuel filter you can see with the fuel in it
[Re: 79powerwagon]
#89185
07/16/08 05:28 PM
07/16/08 05:28 PM
scratchnfotraction
79 is right hear eddy carb and found holes in my line when I put a clear fuel filter on,I could see air bubbles in the fiter need to more
[Re: scratchnfotraction]
#89186
07/16/08 07:34 PM
07/16/08 07:34 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
The Edelbrock carbs do not have a backflow prevention valve on the carb inlet (like the 2-bbl Carter carb on my Super Six did), so the fuel pump needs to be good (read good seals/valves) in order to keep the fuel in the line so it's there when you start the engine. I'm not sure if there's such a thing as a check vavlev for fuel lines, but if the fuel pump isn't keeping the fuel in the line from the pump to the carb, you need a new fuel pump. My Eddy 1406 starts at the first turn of the key and I haven't had any fuel drainback problems. The Carter on the Super Six did have the drainback issue due to a worn fuel pump. It would start right away and run on the fuel that was still in the carb, but once that fuel was used up, the engine would die and I would have to crank it for 15 seconds or so until the fuel pump filled the line and carb again. In you case, even if the fuel is evaporating from the carb bowls, there should still be fuel in the line and it shouldn't take that long for the fuel in the line to fill up the carb's fuel bowls, and eventually start the engine. A quick test would be to run some clear tubing in place of the fuel line from the fuel pump to the carb, crank it over and watch what happens inside the line (disconnect the coil wire so it doesn't fire the engine). If the pump pumps fuel to the carb and it drains back out, you know the pump is not holding pressure and should be replaced. New pumps can be faulty, too.
[Re: MoparTod]
#89187
07/16/08 07:42 PM
07/16/08 07:42 PM
the problem with eddie carbs is that the choke adjustment never stays put and it always changes. deal with it, or go with a manual style choke.
[Re: MoparTod]
#89189
07/17/08 08:52 AM
07/17/08 08:52 AM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
i had this EXACT SAME PROBLEM. What ended up fixing it was a 1" 4-hole phenolic spacer, that stops the gas from boiling out after you shut down the engine, and heat soaks back up into the carb. You'll gain 2 things with the spacer, it will always start perfect, and you'll get a better signal to the carb and have really nice crisp bottom end throttle response. Having your choke adjusted properly also really helps, it was only the spacer that really solved the problem, now i just get in turn the key and vrooommmm, starts every time; where before i would have to crank, crank, crank, take off air cleaner, squirt gas in the carb, crank and start; sometimes i would actually flood it trying to start it.
