Holley 750 Vac Sec #891473
12/29/10 08:56 PM
12/29/10 08:56 PM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
Just put one on my 440 and it doesn't have a port for the PVC. Is this normal for these and if so how do you go about getting it hooked back up? Thanks for any advise!
Re: Holley 750 Vac Sec [Re: indytex96] #891474
12/29/10 09:01 PM
12/29/10 09:01 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Can you find the number on the air horn to post?
Would be kind of odd for one to not have PVC hookup.
Re: Holley 750 Vac Sec [Re: indytex96] #891475
12/29/10 09:48 PM
12/29/10 09:48 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Should be to the rear of the carb. If you have power brakes that gets hooked directly into a manifold port.
Re: Holley 750 Vac Sec [Re: ireland383] #891476
12/29/10 10:27 PM
12/29/10 10:27 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Yup PCV goes to the rear of the carb
1MYTGTX
Re: Holley 750 Vac Sec [Re: 1MYTGTX] #891477
12/29/10 11:05 PM
12/29/10 11:05 PM
SE Kansas
I
I
SE Kansas
Numbers are as follows:
3878261-EH
LIST-3310
194
I like your fuel line with the brass tee, did you fab that or purchase it?
Re: Holley 750 Vac Sec [Re: indytex96] #891478
12/29/10 11:15 PM
12/29/10 11:15 PM
SomeCarGuy Offline
SomeCarGuy  Offline
There is a guy in MCG and maybe other mags that sells the fuel lines for 45 bucks or so. Well worth it or you can fab your own.
Re: Holley 750 Vac Sec [Re: indytex96] #891479
12/29/10 11:22 PM
12/29/10 11:22 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
never seen a 3310 without a large vac port on the back. maybe some one changed the throttle plate.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Holley 750 Vac Sec [Re: moparmarks] #891480
12/30/10 01:50 AM
12/30/10 01:50 AM
SE Kansas
I
I
SE Kansas
Me either, they all I thought had one in the front or back. Not sure how i am going to get my PVC hooked up and hoping someone has an idea.
Re: Holley 750 Vac Sec [Re: indytex96] #891481
12/30/10 01:59 AM
12/30/10 01:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's PCV - Positive Crankcase Ventilation. Not PVC pipe. If your carb doesn't have a port for the PCV on the back you can always just put on a breather filter. Plenty of guys run around with just the breater filters on both valve covers and no pcv valve.
Re: Holley 750 Vac Sec [Re: indytex96] #891482
12/30/10 02:55 AM
12/30/10 02:55 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Do you have room for one of these - a 1" spacer with a 3/8" hose nipple in it.
http://www.jegs.com/i/Mr-Gasket/720/4945/10002/-1?parentProductId=743801
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Holley 750 Vac Sec [Re: indytex96] #891483
12/30/10 12:41 PM
12/30/10 12:41 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
3878261-EH
LIST-3310
194
Whenever you see all those extra numbers before and after the Holley list 3310, that should tell you the application for that particular carb is OEM for something. In this case it may be for a Ford, since there is no provision for a PCV. Often Fords have a spacer with a nipple for PCV. Could be for a Cobra Jet motor, (I'm not going to look it up). I don't like using carbs that old for a number of reasons. It is worth more to the guy who needs the numbers for his restoration. It will likely never run 100% right on your car. You are better off getting a more recent model of 3310.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Holley 750 Vac Sec [Re: racealittle] #891484
12/30/10 02:10 PM
12/30/10 02:10 PM
SE Kansas
I
I
SE Kansas
No I don't have enough room for any spacers as I am running the performer RPM and already real close to the hood. So it sounds as if this 3310 was a factory type carb? If that is the case are they pretty identical to the newer ones internally? Just wondering what I'm in for when I start playing with jets and such. If its going to be too big of a hassel performance wise I'll just shop around for another.
Re: Holley 750 Vac Sec [Re: indytex96] #891485
12/30/10 02:58 PM
12/30/10 02:58 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
It's an OEM Chevy carb.
Don't recall if the one I had came with a pcv nipple.
Re: Holley 750 Vac Sec [Re: RobX4406] #891486
12/30/10 04:34 PM
12/30/10 04:34 PM
SE Kansas
I
I
SE Kansas
Chevy Well thats unfortunate, so can these be tuned like a normal 750? Not sure what jets are in it but car acts like it needs more so am I to assume a factory type carb would be jetted on the lean side?
Re: Holley 750 Vac Sec [Re: indytex96] #891487
12/30/10 05:21 PM
12/30/10 05:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
drill and tap a hole in the back of the manifold into the plenum area just under the carb...
I am truckless..
Re: Holley 750 Vac Sec [Re: 340SHORTY] #891488
12/30/10 05:29 PM
12/30/10 05:29 PM
SE Kansas
I
I
SE Kansas
If thats possible couldn't I just tap into the port for my power brakes?
Re: Holley 750 Vac Sec [Re: indytex96] #891489
12/30/10 06:54 PM
12/30/10 06:54 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Don't be quik to knock the EH 3310, i ran one on a 440 & it ran great in stock form, they are rated at 780 cfm & come with downleg boosters & twin metering blocks, they are very tuneable, your best bet is finding a standard 3310 base & bolt it on, its that easy, they will have the PCV port.
Check this out, there a factory replacement for the 65 HP 396 & are rated one of the best 3310s out there.
http://www.chevelles.com/forums/showthread.php?t=323046
http://www.chevelles.com/classifieds/showproduct.php?product=41052
Re: Holley 750 Vac Sec [Re: indytex96] #891490
12/30/10 07:14 PM
12/30/10 07:14 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
3878261-EH
LIST-3310
194
Yours is a service replacement for the 65 HP 396 Z-16: dated "194" 1= 1971, 9= 9th month (sept), 4= 4th. week of that month.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Holley 750 Vac Sec [Re: joedust451] #891491
12/30/10 08:57 PM
12/30/10 08:57 PM
SE Kansas
I
I
SE Kansas
Thats good info to have thanks guys! I'll play with it and see what I can get.
Re: Holley 750 Vac Sec [Re: indytex96] #891492
12/31/10 01:22 AM
12/31/10 01:22 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Ford taped into the #8 port on some engines.. it works but,, every time you use the brakes it leans out that cylinder.. after time that leads to a burnt valve in the said cylinder... much better to tap the plenum...
I am truckless..
Re: Holley 750 Vac Sec [Re: 340SHORTY] #891493
12/31/10 02:20 AM
12/31/10 02:20 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Kinda curious why a slight vacuum leak during a no load no load situation would burn a valve.
Re: Holley 750 Vac Sec [Re: joedust451] #891494
12/31/10 08:19 AM
12/31/10 08:19 AM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
3878261-EH
LIST-3310
194
I would sell it on Ebay and buy a current version from Quick Fuel.
69 Charger RT
Re: Holley 750 Vac Sec [Re: greenpigs] #891495
12/31/10 09:03 AM
12/31/10 09:03 AM
md
W
wicked Offline
wicked  Offline
W
md
if thats the Gm carb it should have a tube on the carb body below the air cleaner flange for the pcv that goes directly into the venturi, I dont see a ploblem tapping the manifold for the brakes it holds vacuum not draws air, can't see burning a valve unless you drove around with a bad booster, you can't tee into the booster line as then you wouldn't get vacuum on the booster
