Re: Holley 750 Vac Sec [Re: 340SHORTY] #891493
12/31/10 02:20 AM
12/31/10 02:20 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Ford taped into the #8 port on some engines.. it works but,, every time you use the brakes it leans out that cylinder.. after time that leads to a burnt valve in the said cylinder... much better to tap the plenum...
Kinda curious why a slight vacuum leak during a no load no load situation would burn a valve.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Holley 750 Vac Sec [Re: joedust451] #891494
12/31/10 08:19 AM
12/31/10 08:19 AM
Huber Heights Ohio
greenpigs Offline
greenpigs  Offline
Huber Heights Ohio
Numbers are as follows:
3878261-EH
LIST-3310
194
I like your fuel line with the brass tee, did you fab that or purchase it?
Yours is a service replacement for the 65 HP 396 Z-16: dated "194" 1= 1971, 9= 9th month (sept), 4= 4th. week of that month.
I would sell it on Ebay and buy a current version from Quick Fuel.
69 Charger RT
Re: Holley 750 Vac Sec [Re: greenpigs] #891495
12/31/10 09:03 AM
12/31/10 09:03 AM
md
W
wicked Offline
wicked  Offline
W
md
if thats the Gm carb it should have a tube on the carb body below the air cleaner flange for the pcv that goes directly into the venturi, I dont see a ploblem tapping the manifold for the brakes it holds vacuum not draws air, can't see burning a valve unless you drove around with a bad booster, you can't tee into the booster line as then you wouldn't get vacuum on the booster
