Re: Piston skirt coatings worth applying?
[Re: BradH]
#890158
12/28/10 03:34 PM
12/28/10 03:34 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
E booger years back done a artical in Mopar Action about a Rattle coat moly spray. I asked him years later about the application, and part number.... Maybe some one might have that article? This coating if for a dry startup, engine break in. It goes away pretty quickly after intial startup. I dont think a expensive coating on the skirts is worth the money, maybe on the top of the pistons etc, but not the sides.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: dannysbee]
#890162
12/28/10 04:21 PM
12/28/10 04:21 PM
BradH
The true question here is, will the wife let you use her oven to cure the coatings. Better talk to her first.
Oh, no... I've seen first hand what happens when those "apply at home" coatings were used on some valves.
Any coatings I'd use in the future would be applied by somebody to whom I can hold accountable.
[Re: quick77rt ]
#890166
12/28/10 07:28 PM
12/28/10 07:28 PM
Posts: 9,888 Weddington, N.C.
Streetwize
Weddington, N.C.
If coatings help maintain thermal stability by alleviating hot spots, the long term durability/reliability pays off though it might not show up in 'net' HP. Enbgine masters used to be but is no longer relevant to anything "real world"....e.g., 3 foot deep belly pan oil sumps, deck spacers with sleeves (Kaase actually tried to pass-off as "head gaskets" ) aimed at maximizing strokes/rod lengths, etc. Entertaining but on the whole useless to the regular guy because they never publish any of the really interesting stuff in any significant detail. I'm pretty impressed with the fit and finish of the Mahle Coated pistons in my 414, I could have opted for the standard Diamond/Ross/JE's of scores of builds past but I wanted to try something different. And the pricing was attractive and they were locally (NC) manufactured. (Where's the American flag emoticon?) Time will tell but companies have poured 10's of millions into the development of some of these coatings, I'm sure much (if not all) of the technology has spun-off/trickled down from NASA, it's not too far fetched to expect mass-produced ceramic based pistons and perhaps valvetrain components displacing metal based alloys in the not too distant future. As for skirt scuffing well...you basically rely on "random" oil slinging to protect the piston and bore surfaces, there's a reason modern engines and race motors have strategic oil 'jets' and dedicated hydrualic oil control systems. No doubt you can do a lot more with a lot les.....if it's surgically applied and tested.
[Re: 602heavy]
#890172
12/28/10 08:23 PM
12/28/10 08:23 PM
BradH
My 452's Ross pistons had some noticeable scuffing on the skirts due to being run w/ too little oil.
How did you come to this conclusion?
Punch in this search exactly and start reading the posts returned beginning approx. 11/16/2009. I'm not going thru it all over again...
[Re: quick77rt ]
#890174
12/28/10 08:31 PM
12/28/10 08:31 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Don't fear the coating It will help with scuffing and clearance issues. Call swain tech if you want the real I would imagine it wont be long before cp, diamond, and the other mfgs offer coatings. BTW getting some heat into the motor before beating on it will reduce scuffing.
[Re: BradH]
#890176
12/29/10 12:22 AM
12/29/10 12:22 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
I have several engines with Ros pistons, I think there alloy(piston skirts ) is very soft Especially their close tolerance alloy I'm using Diamond pistons now with their close tolerance alloy with a lot better results On second thoughts maybe Ross alloys are to hard Resulting in scrathing up the cylinder walls and piston skirts
