A buddy of mine just pulled out from a 383 a purple cam. It looks recently installed. Anyway, he just picked the motor up and trying to determine what cam is in it from the casting number on the end of the cam. It has KB162 pistons in it (number cast on the inside of the piston). The casting number on the camshaft is 201798. I looked through everything I have and cannot find any info from that. Does anyone happen to have any more info. The number is on the sprocket side on the end of the cam. Thanks. It has hydraulic valve train.
