12/27/10 12:20 PM
12/27/10 12:20 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Bought a sweet low miler 318 from a 91 pickup. I want to put this in my 75 powerwagon, i plan on using my intake and carb. Does this engine have a fuel pump essentric on it, will the one from my old smallblock bolt on to that roller cam if it doesnt have one already???
If I hafta come in and getchya.......I'm gonna getchya!
Re: 91 318 [Re: Gt383] #889555
12/27/10 12:28 PM
12/27/10 12:28 PM
scratchnfotraction Offline
no,it will have a short nose cam
you can get a extintion/adaptor to run mech fuel pump from Hughes for it
if you swap in any retro roller came order it with long nose
I used a lunati voodoo roller cam with long nose in my 88-318 with a set of the comp 901-16 springs
they drop on with heads on engine and use stock seal/retainers
Re: 91 318 [Re: scratchnfotraction] #889556
12/27/10 12:34 PM
12/27/10 12:34 PM
OH! FYI,it will have the oil thru roller lifters and hollow push rods
so thats one step closer to swaping on mag heads for a pre-mag roller cam hybred in the future
it most likly oil thru the lifters/PR and thru the heads/rockers like the older LA engines
mine does and so did the 1990 parts engine I had
Re: 91 318 [Re: scratchnfotraction] #889557
12/27/10 06:14 PM
12/27/10 06:14 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
ok electric pump then huh.....
Re: 91 318 [Re: Gt383] #889558
12/27/10 07:13 PM
12/27/10 07:13 PM
you will need a la t-cover with the extetion also
mag cover wont have the hole for the FP either
Re: 91 318 [Re: scratchnfotraction] #889559
12/27/10 09:40 PM
12/27/10 09:40 PM
Southwest
way2fast Offline
way2fast  Offline
Southwest
Not to high-jack the thread...but I just took the eccentric off my '79 parts motor and put it on my '90 Roller cam. The T cover had a block off plate where the mech pump would go, so I just removed it and put in the pump. Are the '91's different? Do I need an extension on the cam?
Go Fast and Swerve!
Re: 91 318 [Re: way2fast] #889560
12/27/10 09:44 PM
12/27/10 09:44 PM
no some had a long nose cam also on the tbi motors
must have been a early one,my 1990 cam on the shelf is a short one though
never say never with mopar,they used what they had on hand to use up all the parts in stock
like 6-pack rods in motor homes
all magnum engine 92-up have a short one
Re: 91 318 [Re: scratchnfotraction] #889561
12/27/10 10:10 PM
12/27/10 10:10 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
this 1 hasa block off plate....gonna tear it apart
Re: 91 318 [Re: Gt383] #889562
12/28/10 12:19 AM
12/28/10 12:19 AM
may get lucky and have a long nose roller cam then
I have short tbi roller cam on the shelf I can measure for you also
