Re: AN hose assembly tool
[Re: codfish]
#889520
12/27/10 11:45 AM
12/27/10 11:45 AM
Posts: 6,295 U.S.
moparniac
U.S.
there is an aluminum vise jig just for holding the an fitting... I know they sell a fancy big tool setup but I have never had a need to use that!
Mopar Performance
[Re: codfish]
#889522
12/27/10 12:23 PM
12/27/10 12:23 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I have two of them.........one attached to the end of each arm. The big thing is the cut........if you get that clean , you are golden. Tape it up and zip it with a cut off wheel .....blow the crud out of the line and use a bit-o- motor oil on the inside of the line. Works 99.9873 % of the time.
[Re: codfish]
#889523
12/27/10 12:23 PM
12/27/10 12:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What was the tool that was mentioned here awile back that made it easier to put these type of hose ends on braided lines?
http://www.summitracing.com/parts/SUM-220890/
thanks
codfish
I just tape the area of the hose where I will cut (I cut in the middle of the tape) and it holds the wires nice so you can slide the fitting over the hose
[Re: MR_P_BODY]
#889526
12/27/10 12:43 PM
12/27/10 12:43 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
thanks
codfish
So do you leave the tape on during install, and remove it later, or will the fitting cover the tape enough so that you can't see it?
thanks alot
gary
[Re: codfish]
#889527
12/27/10 12:46 PM
12/27/10 12:46 PM
Posts: 6,295 U.S.
moparniac
U.S.
the fitting will go over the tape(and not be visible if to long)! I used the clear strapping tape in the past! I also use to apply a lil petroleum jelly also to help the install!
Mopar Performance
[Re: codfish]
#889528
12/27/10 12:51 PM
12/27/10 12:51 PM
MR_P_BODY
thanks
codfish
thanks alot
gary
I just leave it on... you cant see it (I use electrical tape)
