Re: Vacuum pump inlet location
[Re: TheBlackCar]
#888981
12/27/10 12:37 AM
12/27/10 12:37 AM
Posts: 5,618 long island NY
Ari440
long island NY
top of the valve cover inbetween the rockers
Im using jessel 1.7 ratio and indy spraybar valve covers
1.39 9.85 - 137 mph
[Re: Ari440]
#888982
12/27/10 12:48 AM
12/27/10 12:48 AM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Mine has been in a few places. We settled on the inside part of the valvecover centered on a rocker stand. Seems to be the best location for me at least. I have never seen anyone successfully use the fuel pump boss on a west sump Mopar application FWIW. You can see mine in the picture of the drivers side cover. No line in it in the pic but the fitting is there.
[Re: Al_Alguire]
#888983
12/27/10 12:50 AM
12/27/10 12:50 AM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
You can see mine in the picture of the drivers side cover. No line in it in the pic but the fitting is there. Mine is in same location Passenger side , works great there
[Re: dvw]
#888984
12/27/10 04:05 AM
12/27/10 04:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Has anyone fed their vacuum pump on a big block from the fuel pump block off plate? I'm running a Jesel so theres no chain flinging oil around. It appears to be in a well baffled location. Also would make for a clean install. What do you think? Doug
I would... like you said, no chain, that would make for a clean point... I think I might shield the port also just to make sure about oil flying around(I never seen a video of that area)
