wil a 71 plymouth leafspring fit on a 73 charger? #888110
12/25/10 06:42 PM
12/25/10 06:42 PM
netherlands
smallstroker Offline OP
netherlands
i can buy a set monoleafs from a 71 plymouth satelite wagon. but wil it fit under my 73 charger.
the front spring length is 22 " that is the sam as my original leafs
is a monoleaf safe for a street car?
thanks
Re: wil a 71 plymouth leafspring fit on a 73 charger? [Re: smallstroker] #888111
12/26/10 02:33 PM
12/26/10 02:33 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If the earlier springs are the same legnth you'd need all the associated hardware {front hanger,shock plate, u bolts, shackles, etc..} to make it an easy swap...But even so...Since you're going from an isolated rear set-up {with the rubber components between the springs/rear} you'd still need to change out the rear housing spring perches to the old style which would require welding...
Re: wil a 71 plymouth leafspring fit on a 73 charger? [Re: screamindriver] #888112
12/26/10 03:33 PM
12/26/10 03:33 PM
netherlands
netherlands
i don't have the isolators , i allready have a 71 rear axle and shock plates from a 71 r/t
the only thing i am woried about the total lengt of the leaf spring??
Re: wil a 71 plymouth leafspring fit on a 73 charger? [Re: smallstroker] #888113
12/26/10 05:20 PM
12/26/10 05:20 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
lengths are the same.
1971 Challenger
Re: wil a 71 plymouth leafspring fit on a 73 charger? [Re: screamindriver] #888114
12/26/10 06:19 PM
12/26/10 06:19 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not really... you can simply enlarge the hole to the thicker guide studs ( earliers are 5/16", laters are 3/8" ), and add the bushings attached to this studs what inserts into the isolation pads.
Of course if you want to keep the 73 and lates isolation stuff
Now, dunno if the SWs makes some differences. I know 2 doors and 4 doors are the same. Myself, bought new 71/72 Coronet leafs and mounted on my 74 Charger
74s has another detail, the front eye spring bushing is thicker on rubber section, what means the crossing bolt is smaller diameter. That makes difference also on bracket to unibody ( smaller hole ) I simply got the right front eye bushings to match with my 74 brackets
Re: wil a 71 plymouth leafspring fit on a 73 charger? [Re: NachoRT74] #888115
12/26/10 10:55 PM
12/26/10 10:55 PM
Harrisburg, Pa.
Harrisburg, Pa.
I've always assumed that dumping that horrible islolated rear end set-up went along with the old style spring swap...
