Blow thru vs regular #887182
12/24/10 12:24 PM
12/24/10 12:24 PM
New Lenox IL
cudadon Offline OP
cudadon  Offline OP
New Lenox IL
Whats the diff. between the 2?
Do you have to use blow thru with a Paxton SC?
Thanks, Don
Re: Blow thru vs regular [Re: cudadon] #887183
12/24/10 12:25 PM
12/24/10 12:25 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Blow thru is when the blower or turbo is pushing through the carb. Draw through is where the carb is in front of the blower and the blower or turbo pulls the fuel from the carb. Draw through is pretty much dead other than roots blower applications.
68 Barracuda Formula S 340
Re: Blow thru vs regular [Re: cudadon] #887184
12/24/10 03:46 PM
12/24/10 03:46 PM
Thanks, Don
You could do either, your choice Pull thru is probally pretty hard to start first time if you don't have a primer in the intake stream after the blower My choice would be electronic fuel injection
Re: Blow thru vs regular [Re: cudadon] #887185
12/24/10 05:12 PM
12/24/10 05:12 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Thanks, Don
Yes, if your not using Fuel injection
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Blow thru vs regular [Re: Cab_Burge] #887186
12/25/10 06:01 AM
12/25/10 06:01 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Thanks, Don
My friend had a draw through setup on a 70 capri 454. After a while of tuning on it he got it to start pretty good.
