fan clutch for 4-core radiator
#88718
07/14/08 09:45 PM
07/14/08 09:45 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang... I have a friend that has expanded his factory 3-core radiator in his v-code '71 Challenger R/T to a 4-core. Since the core thickness is the same as the thickness of the upper tank, he needs to find a fan clutch which will work with this modification. Anyone out there running a 4-core with the factory upper 26" tank while at the same time using their factory shroud and fan.
Thanks.. Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: fan clutch for 4-core radiator
[Re: hemi68charger]
#88719
07/15/08 06:02 PM
07/15/08 06:02 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
If he uses a 68-70 070 clutch it would work, its 1/4 inch shorter than the correct 71 clutch
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#88720
07/15/08 09:41 PM
07/15/08 09:41 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Dave,you didn't include price!
[Re: radiatorman]
#88723
07/18/08 03:36 PM
07/18/08 03:36 PM
hemi68charger
Houston, Tx
Thanks guys.................. Got it and I'll pass this on to him...
