Re: old school but it works well.! 292/509 lets talk.
[Re: @#$%&*!]
#886321
12/25/10 11:00 PM
12/25/10 11:00 PM
Posts: 768 Maryville tn
67coronetman
Maryville tn
Yes there is but i really like the old profile myself now that is what i like other like the new one and that is ok too we all have a choice.!
Old car are me......
[Re: @#$%&*!]
#886322
12/25/10 11:01 PM
12/25/10 11:01 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I was looking through the online MP catalog and there are TWO cams with .509"/292 specs. One has 6 degrees less overlap for improved street manners. (if I remember the data right)
Yeah, & the one on the 114 is a p*ssi cam, you want the one on the 108 & dial it in around 102, i've run this cam in 3 440s & even lined straight up they rocked.
Re: I know its old school but it works well.! 292/509 cam
[Re: 6PakBee]
#886324
12/25/10 11:37 PM
12/25/10 11:37 PM
67coronetman
Maryville tn
I am glad other like the racer browns but i will just stick with the 292/509 mopar cam for me but the rest out there some good info to look at.!
[Re: 6PakBee]
#886325
12/26/10 01:04 AM
12/26/10 01:04 AM
67coronetman
Maryville tn
Even though i like the 292/509 cam i am always willing to help other look at others that have done a combo alittle different.!
** But i am still a 292/509 cam man.!
[Re: joedust451]
#886326
12/26/10 01:33 AM
12/26/10 01:33 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Gee, thanks. I was just pointing out that there is more than one that fits the description in the title. I think they're BOTH p*ssi cams, they are hydraulic after all. And only 1/2" lift? what a joke.
[Re: @#$%&*!]
#886327
12/26/10 01:42 AM
12/26/10 01:42 AM
67coronetman
Maryville tn
Yea oh well we all have to make our selfs feel good one way or another.!
[Re: 6PakBee]
#886328
12/26/10 01:46 AM
12/26/10 01:46 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
If you really like this cam, I suggest you get a Racer Brown SSH 44. The MP 509 cam was a near copy or the SSH 44. Before there was Direct Connection or the later Mopar Performance the Mopar race bulletins recommended Racer Brown cams and many of the Purple shafts were in fact copies of Racer Brown designs. The advantage of getting the "real" 509 cam from Jim Dowell at Racer Brown is that he will custom tailor it to your combination. He will give you the LSA best suited to your car and also grind in the best advance for you. I've dealt with Jim in the past and have always gotten good service and sound advice.
The SSH-44 and its little brother the SSH-25 are both great cams.
Cam ADV, DUR-----lift-----.050 Dur
SSH-25 ---286------.485-----236
SSH-44----292------.510-----243 ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
MP-509----292------.509-----248
All of these Old school cams are great. Todays modern cams have nothing on them except a little extra lift.
Example: The 35 year old MP 509 248* duration cam has the following intake valve timing at a 104* ITC. Followed by a MODERN day cam from HUGHES with a 250* duration.
MP 509 Intake. open @ 20* BTDC, close @ 48* ABDC
Hughes, 5056---open @ 20* BTDC, close @ 50* ABDC
35 years later and we have nearly the Same exact timing events with a similer size modern cam,- the extra 2* of the 5056 250* duration @ .050
IMO, The tricky part of the cam Design was figured out YEARS ago. The above shows that IMO
Example; If you have 248* of intaske duration to play with, where do you put the valve events at BTDC and ABDC??
Open @ TDC, close @ 68* ABDC, OR
open @ 10* BTDC, close @ 58* ABDC, OR
open @ 20* BTDC, close @ 48* ABDC, OR
open @ 30* BTDC, close @ 38* ABDC.
And after 35 Plus years of Study, the answer is,??
The same as 35 years before!! . mike ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Sport440]
#886329
12/26/10 02:03 AM
12/26/10 02:03 AM
67coronetman
Maryville tn
That is great info.! So i will let other look at it and they can make up there own minds as to witch cam to use.
** But as i have said i like the 35 yr old mopar cam my choice.!
** look guys this is not a debate to see who knows more or who is better all i ask for was those that like the mopar 292/509 cam to post your combos and how well it worked for you so other may like to Try it out and if someone wants something different that's ok to.!
[Re: 67coronetman]
#886330
12/26/10 07:14 AM
12/26/10 07:14 AM
Posts: 969 OH--IO
360904
OH--IO
I like being a old school person. I just put this together and hope it works well. 360 30 over 292/508 "smallblock" installed at 106 iron heads 202/160 stage 3 ported low gear 904 w/4000 stall 4.30 w/28" hosier 3300 lbs with me in it ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 67coronetman]
#886331
12/26/10 10:57 AM
12/26/10 10:57 AM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
Being "old school" is not for all. You have to be cool with running at a certain level. Good for street/strip and bracket racing. Which is me. Knocking the "only 1/2" lift" is ok too. If you only run "old school" iron heads you know that the ports basically stall at over .500 (aka 1/2" lift). Yeah, we could debate that there's more "area under the curve" with more modern profiles and there's also the 1.6 ratio rockers to band-aid it too. Whatever, it's bang for the buck. "old schoolers" know that the adjustable valvetrain opens a Pandora's box of additional spending. Can you go faster any cheaper????? Probably not. Can you run more consistent, or even faster, than a guy with more modern technology but not dialed in???? It certainly happens. Here's my old school 69 Rr. It has sat there so long it's very embarrassing to mention it. BUT I finally started to get back to it in the last few months........... http://www.moparts.org/moparts/picture/mopar03/moparty/img/DCP_0479.JPGI'll be running some old narrow front runner Ansen slots, the big 11.75" discs and a 6 Barrel hood.
[Re: Dean_Kuzluzski]
#886332
12/26/10 11:30 AM
12/26/10 11:30 AM
Posts: 2,782 USA
JoesMopar
USA
I don't have the Mopar brand cam, but I do have the Comp "nostalgia" or whatever series they call it, 292/299 .509/.509 cam in my Charger with all the "wrong" parts...
What I mean by wrong parts is a 3000-3200 stall and 3.55 gears.
I'm running closed chamber Edelbrock heads, 2" Super Comp headers, Torker I intake, 870 Holley, Crane Gold Race roller rockers, KB flat tops, zero decked block, etc etc. I am also using Rhoads Lifters, which supposedly take a little radicalness out of the cam.
Either way, with the 3.55's and the "lower" stall, this thing still hauls ass, it's not a slug like everyone says it would be with that combo. I'm running 295/50/15 tires on the rear and this thing lights them up with just a light stab at the gas pedal. I also did a 50-100mph run with a video and it made it in 6 seconds (no track around here to run it on). Either way, I don't race the car, just built it to enjoy it and have been happy with this cam.
[Re: 360904]
#886334
12/26/10 08:13 PM
12/26/10 08:13 PM
67coronetman
Maryville tn
That is a very nice ride so what has it ran or did you get a chance to yet let me know thanks for the info have a great new year.!
#886335
12/26/10 08:22 PM
12/26/10 08:22 PM
67coronetman
Maryville tn
Yes Sir i agree that we need to look at what we are building and try and get the most. Please i am not here to say ( old school is the only way i just think that we all have a level of money we can spend and so on so use it for what works best for you and your car and the items you have at hand.!) I myself have up grades and i still would rather use a 292/509 mopar cam in my 448 cu in street car but that is me i wont everone to ues what they want but if you are like me and like the old school profile 292/509 cam i say use it.! By the way nice RR send pics when done and back on the road thanks for the reply.!
[Re: joewhite440]
#886336
12/26/10 08:27 PM
12/26/10 08:27 PM
67coronetman
Maryville tn
Hey Joe its mark in Tn i knew it was my hard core mopar friend like me nice ride and that is moving for an old combo this is what i am saying sometimes we only need to be frugal and it all works out i like it alot hope you and your family have a great new years & that goes for everyone out here on moparts i hope you and your family have a nice new years.!
[Re: joewhite440]
#886337
12/26/10 11:22 PM
12/26/10 11:22 PM
67coronetman
Maryville tn
Hey joe anything new you are working on lets talk maybe u have something i need our i can help you out.!
[Re: Dads426]
#886339
12/27/10 01:02 AM
12/27/10 01:02 AM
67coronetman
Maryville tn
Wow that's a very clean looking car did it have stock heads.? factory or aftermarket what type tires out back when you ran it was the 292/509 cam the old profile.?
