offset grinding a 340 crank...?? #886082
12/23/10 04:31 AM
12/23/10 04:31 AM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
Anyone ever offset grind a OEM 340 crank? If so to what stroke? Thanks!
Re: offset grinding a 340 crank...?? [Re: cudadoug] #886083
12/23/10 06:30 AM
12/23/10 06:30 AM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
We have used 2 different ofset ground cranks,4340 and both broke after 250 to300 eight mile passes one on the front at 1&2 rods the second at 7&8 rod will not use any more of them will stay with the 4" stroke only
Thad
