In trying to get the wagon done for Carlisle, looks like my engine will be a el cheapo hone, re-ring and bearing of a 413. It has 10.1 compression. A refresh of the heads, springs, seals etc, and maybe a mild cleanup, and the crane ductile iron rockers. Also using a performer rpm. I'll also be running a 3 inch exhaust with bullet mufflers, as i like LOUD.
Would a Lunati bracket master 2 be a good choice?
http://www.summitracing.com/parts/LUN-00032LK/Keep in mind it's a 4,400 wagon with 3.91's. I don't mind having to run a 3,000+ stall if need be.
What i'm looking for is good power and an aggressive idle. Not looking to be a killer with this combo, but something that runs good.
My boy has a similar set up in his 3,900lb '58 plymouth and that goes low 12's. only difference is he has a stock bore 440.
thanks.
