Been doing this for years on drag, circle and not had a problem with it. As for having one seize so what you will still be floating in the piston. That is the one advantage to free floating pins. The other being ease of piston swap. Other than that there is no advantage to free floating a piston. As for seizing the pinon the rod I have seen bushed rods seize too.
