Re: Floating pins....Is this correct??
[Re: Bob_Coomer]
#884832
12/20/10 11:48 PM
12/20/10 11:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've seen that a few times... never had any pin issues
Think they will be OK Mr-P? Given clearance is correct? Clearance is correct on these BTW... Anyone else run them like this?
I bought a engine and thats the way it was set up... I ran it for 3 years then sold the car
[Re: hemiiroc]
#884833
12/20/10 11:50 PM
12/20/10 11:50 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Are the pin bosses on the pistons drilled for oil entrance? If not,,should be. I have done this in the 'past',,with no problems.
If you like drag racing, support your local track.
[Re: CHAPPER]
#884834
12/20/10 11:54 PM
12/20/10 11:54 PM
MR_P_BODY
Also see if the rod has a oil hole on the top
[Re: MR_P_BODY]
#884836
12/21/10 12:07 AM
12/21/10 12:07 AM
Posts: 622 ct
jkgtx
ct
have a 440 i built 20= years ago small end honed and drilled did lots bracket racing no problems running high elevens
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
[Re: Bob_Coomer]
#884837
12/21/10 12:08 AM
12/21/10 12:08 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
They will be fine. Same deal we did for years with stock small block rods. As long as your not running high rpms, it works just fine. Cant hurt to add a chamfered oil hole from the top of the small rod end into the pin hole.
RIP Monte Smith
[Re: jkgtx]
#884838
12/21/10 12:11 AM
12/21/10 12:11 AM
Posts: 614 Michigan
Get-X
Done it many times, never had a problem.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: sam64]
#884840
12/21/10 12:40 AM
12/21/10 12:40 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
No oil holes on the pistons bottom on the area of the wrist pin boss. The rod does have a oil hole on top through to the pin area. Thanks Guys This is going in a daily driver BTW.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#884843
12/21/10 12:45 AM
12/21/10 12:45 AM
MR_P_BODY
I just had the hole in the rod... you should be fine with the proper clearance
[Re: Bob_Coomer]
#884845
12/21/10 01:54 AM
12/21/10 01:54 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
there is no gain in this app so then just press a pin in another rod and have at it. But i would not take a chance of steel to steel with locks on the pistons for the price of bushings or coating.
I guess me being a buisness and having to stand behind everything makes me stay on the careful side.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#884846
12/21/10 01:09 PM
12/21/10 01:09 PM
Posts: 5,080 organ
maximum entropy
organ
i've run no bushing before, and no oil hole. no problem at all. 8000 rpm small block chevy that saw some street duty, so it was subjected to a rainbow of operating regimes. that thing was hella fast, and hella reliable. for a chevy.
