Oil Pan #884605
12/20/10 10:07 PM
12/20/10 10:07 PM
Hamburg, Pa.
72 RR DUDE Offline OP
Hamburg, Pa.
I have an oil pan with the no. 394 on the bottom which I believe fits a 340 in an A-Body. Will this pan work on a 1972 B-Body with a 340? If it doesn't work what is the right no?
Thanks Moparts
Re: Oil Pan [Re: 72 RR DUDE] #884606
12/21/10 12:37 AM
12/21/10 12:37 AM
Assuming that # is an A body 340/318 center sump pan, I believe it will fit the B body
