Re: Best front disc. set up for street/strip car...
[Re: BloFish]
#884392
12/20/10 03:38 PM
12/20/10 03:38 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
this same question has popped up like 4 times in the past few days
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#884393
12/20/10 03:39 PM
12/20/10 03:39 PM
sixpackgut
Charleston
also, you should let me decide what i want on my car anyway!
[Re: BloFish]
#884395
12/20/10 03:55 PM
12/20/10 03:55 PM
Triple Threat
Renton Washington
The topic has come up as to race only brake systems. Although I'm not the OP, the street aspect interests me more. Who can and has got away with running "drag only" set ups on the street. Or if those should be axed in favor of the street/strip kits. Weight savings are greater with the drag kits, but can the rotors take the abuse of the streets? You figure if they can slow a car from 150+ and not turn to mush they should be able to handle a bit of street driving.
Ray, Your car has wilwoods?
[Re: Triple Threat]
#884396
12/20/10 04:09 PM
12/20/10 04:09 PM
sixpackgut
Charleston
yes, i have the street vented rotor in the front. the backs i got in a trade and they are just the thin rotor. i know alot of people complain about them but they work great for me.
one thing i noticed in the one members post with the strange brakes, it looks like a steel hat goes over the rotor. with the wilwoods, they say to not use steel wheels with their alumunum hubs. i have nice rallyes i would like to run every once in a while but afraid to put them on now with the wilwoods
[Re: BloFish]
#884397
12/20/10 04:53 PM
12/20/10 04:53 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I used the Wilwood HD kit on the front of my Demon,soon I will use the car as a street/strip car and plan on keeping the brakes as is.The car stops great at the track,MUCH better than the 10" drums it had originally.
[Re: Chris2581]
#884398
12/20/10 05:02 PM
12/20/10 05:02 PM
Triple Threat
Renton Washington
I received an E-mail from Ron Silva on the subject of race brakes on the street. He gave me the go ahead to post this in case anyone else was interested. Quote:
I had Wilwood drag race Brakes all the way around on my Demon. The 3/8” solid rotor with 4 piston Calipers. The brakes would fade after about 3 or 4 consecutive hard stops from 60MPH. I then went to the cast iron vented front rotors and did not get any more braking ability. All it did was give better pad wear and quieter operation if anything.
In my opinion the biggest thing you have to worry about is capacity (3/8” solid rotor), obviously, and the fact that they are not weather sealed. They should not be used in the rain or hosed down when washing your car. I almost never washed my car with water and if I did I wrapped the wheels/tires to keep them dry. If I wanted to wash the wheels/tires I always took them off the car.
I also think the Wilwood stuff was junk and I would never buy it again unless I was on a severely tight budget. My rotors wobbled (steering wheel would shake when braking) and they sent me new rotors and the new ones were no better. I had to keep clocking the rotors and the adapter rings and measuring runout and it took FOREVER. I finally got it where it was acceptable but I will never go through that again. There is something like 25 possibilities to try to get the runout low enough, but it never got anywhere close to production tolerances. I think I started at .012 and got it as low as .006 runout. ....... .012 would shake the steering wheel pretty good and the car was no fun to drive.
I have Mark Williams on the Valiant and there Brakes are better in every way. They cost $$ But well worth it if you can save up for them. Yes, I had to ship them my Spindles but that was worth it too as I believe they magnafluxed them as well as minor machining.
Anyhow, wilwood or mark williams are perfectly fine for limited street driving. I have NEVER had them fade on the street or race track but I am aware of their limited capacity. After 4 or 5 stops they WILL give up. I have never had a situation on the street where I was FORCED to stop hard 4 or 5 times in a row.
Ron Silva.
[Re: Triple Threat]
#884399
12/20/10 05:27 PM
12/20/10 05:27 PM
sixpackgut
Charleston
FWIW, i did brakes on a buick, rotors had .005 of runout.i called the guy and told him i was about to waste his money but he said change them. never did i think it was possible that they were causing the wheel to shake so bad when stopping but i changed them and it stopped. i have not experienced any of those problems with my wilwoods but everyone complains so maybe its just me
[Re: sixpackgut]
#884404
12/20/10 09:40 PM
12/20/10 09:40 PM
Posts: 31,035 Oregon
AndyF
I developed the Wilwood + 11.75 kit years ago just for street/strip cars. That way you can have the low cost and reliability of the factory rotor, but you save a bunch of weight by going with the aluminum caliper.
I'm not a big fan of using race kits on the street. The lightweight aluminum hubs aren't really designed to handle potholes and such. Of course, some folks do it and don't have problems so you just have to make a decision based on how much you drive the car and the conditions that you drive it in.
you have a kit to fit wilwood calipers on a stock rotor? or a big rotor? who sells your kit?
Yes, I've had a kit that hangs a Wilwood caliper on a stock rotor for years. Mancini Racing sells it as do lots of other places.
[Re: AndyF]
#884407
12/20/10 10:26 PM
12/20/10 10:26 PM
sixpackgut
Charleston
thats cool. Thanks Andy
[Re: W5Duster436]
#884409
12/20/10 11:38 PM
12/20/10 11:38 PM
AndyF
This is for b/e though right? Nothing to work with the factory 70/71 A-body discs?
I am actually thinking of just having my originals redrilled at this point. Wilwood kits seem to be on an indefinite backorder.
My kit works with any car that has the 11.75 rotors. A-body, B-body, E-body, FMJ, etc. Those rotors can be fitted to most anything once the correct knuckle is installed.
