Re: How busy is your pit area?????????
[Re: ChrisJohnston669]
#883718
12/19/10 06:51 PM
12/19/10 06:51 PM
Posts: 1,019 Finland
mafo
Finland
lash, spring pressure, data, chute, coffee, gas, maybe 4-link and shocks, jets, co2 bottle, did I forget something?, another cup of coffee, usually we have the trans out once a weekend and maybe a converter swap, this is off course when things go as planned...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: MR_P_BODY]
#883722
12/19/10 09:32 PM
12/19/10 09:32 PM
Posts: 2,110 toledo, ohio
plasticfantastic
toledo, ohio
During a TnT I do all sorts of stuff between runs but at a race its just the normal stuff... fuel every third round, check the tires before I head to the lanes just to make sure they are high enough so I can set them to the final pressure in the lanes, check the weather, set the dial in, check water temps... just your normal stuff... I try to sit in the trailer (in the AC as much as possible... or doing some cooking)
not that its what I seek out to do, but I normally watch Mike do all that stuff he just mentioned. If he tells me to do something, I do it.
[Re: dustergirl340]
#883724
12/19/10 10:46 PM
12/19/10 10:46 PM
plasticfantastic
toledo, ohio
Don't do much between rounds, unless my car is slinging belts. Then I leave it to my crew chief/head mechanic (husband) to fix it while I go talk to Plastic Fantastic's dad.
its the highlight of his race day...
[Re: plasticfantastic]
#883725
12/19/10 10:52 PM
12/19/10 10:52 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
play cornhole go bs with people go stand on the starting line. a lot of you have pictures with me in the background from trails. i hate working on my stuff between rounds but ill helpo out with anyone else if they have a problem...
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: rebel]
#883728
12/19/10 11:15 PM
12/19/10 11:15 PM
Triple Threat
Renton Washington
I do just about nothing between rounds. If its hot out I open the hood. I never add fuel and I'll add air front and rear if necessary right when they call us up for the next round.
[Re: Triple Threat]
#883729
12/19/10 11:56 PM
12/19/10 11:56 PM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
I usually go by myself. At the SCSN vegas I ran 2 classes.One was pro tree no box where I deep staged the other was an electronics bracket class w/ box. During some time trials this was a between rounds procedure Refuel after every run I run Methanol Refill 5 gal fuel jugs Changed Jets Adjusted the 4 link Cool or service engine or transmission remove or install the delay box Write or remove deep for staging review data logger enter runs in log book set tire pressure review delay box setting or stall rpm review haw shallow or deep from previous run Review weather from last run Cuss breathe drink water maybe eat a snack There were a few passes where I was about to go nuts But I sure had a GREAT TIME!
[Re: Triple Threat]
#883731
12/20/10 12:00 AM
12/20/10 12:00 AM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Some times if there is a large car count or several classes, I'll enter two classes just to stay busy. If I'm not busy, I tend to get bored. When I get bored, sometimes I get complacent and when that happens, there's no telling what I might do (or not do). Nothing good ever comes from that. And I fill the fuel tank after every pass, until I get to the semi finals, then all my focus goes into getting the driver mentally prepared. Brian Dunnigan
[Re: '72CudaRacer]
#883732
12/20/10 12:52 AM
12/20/10 12:52 AM
dartman366
Mt. Vernon, Ohio
I need a smiley kicked back in a lounge chair,,I air the tires and put in a splash of fuel just after they call my class, then head to the lane's.
[Re: Al_Alguire]
#883733
12/20/10 01:18 AM
12/20/10 01:18 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Input my timeslip data into my ET predictor. Fill it with fuel when needed. Hook up the battery charger. Cool down the car. Check the tires before we leave. Check the weather station an ET predictor before I leave the pit stall. Does not take long to do this stuff so there is plenty of time to do nothing....
That all depends if you're going rounds.. It gets a lot more hectic deep into the rounds...
Chris..
[Re: Chassisman]
#883737
12/20/10 06:55 PM
12/20/10 06:55 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I race....my wife races....and our boy has the junior that runs at the same events.....do I REALLY need to explain anymore?
Not to me
