If the distance from the center of the pivot point bolt hole at the top where the pedal swings, down to the center of the hole that the M/C pushrod bolts into is 3" and the distance from the center of the aforementioned top pivot point bolt hole all the way down to the imaginary line where your foot comes at the pedal at a 90 deg right angle is 12" then it is a 4 to 1 ratio. EDIT if your M/C is going bad or if you want a dual bowl for safety reasons the simplest upgrade would be a 67-69 B body 4 wheel drum brake M/C (it's a dual bowl). (re)use your old pushrod and unscrew the rear brake line from the brass splitter and connect it to the front (closest to the radiator) M/C port w a length (or 2) of prefabbed 3/16" brake line using a double female brass inverted flare fitting in the "Edelman" fitting section in your parts house along w a male inverted flare brass "edelman" fitting to plug the hole in the brass splitter where the orig rear line screwed into
