Re: 1973 Duster cutting out... Any ideas???
[Re: firtdog]
#883357
12/18/10 10:03 PM
12/18/10 10:03 PM
RapidRobert
When did it start/any recent part changes. runs OK ex for if you floor it? check the easy stuff; AP squirt/filter/float level/vac leak then hook a can of gas to the pump inlet & set it in the eng compartment & take it out & see if it's a fuel delivery prob rearward from the tank
[Re: firtdog]
#883359
12/18/10 11:34 PM
12/18/10 11:34 PM
RapidRobert
Check the plugs/wires also.
[Re: firtdog]
#883360
12/18/10 11:37 PM
12/18/10 11:37 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
1 BBL carb, or 2 bbl? I remember the 1 bbl's on my Dad's '67 valiant and '71 Swinger seemed to need frequent rebuilds because of stalling and hesitation.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#883361
12/18/10 11:53 PM
12/18/10 11:53 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
might be sucking trash from tank. hard work stuffs the filter, less load lets it settle, and run normal. did you clean out the tank? try a see through filter, just long enough so you can see whats going on. some guys hate them, some love them. i put one inline, whenever i want to see what the fuels doing at the carb.
