Offset Rockers for Edelbrock Victors: Who has the best?
#883061
12/18/10 03:25 PM
12/18/10 03:25 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Was looking at different brands to buy and wondering what brands were good. We are going to just buy the 8 necessary offset rockers. From what we saw, Crane, Hughes, and Harland Sharp had some rockers available for the Victor with Harland Sharp being the most expensive. What are you guys thoughts or suggestions?
Adriel Paradise Substation Design Engineer III
Re: Offset Rockers for Edelbrock Victors: Who has the best?
[Re: Adrielp]
#883063
12/18/10 03:32 PM
12/18/10 03:32 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Out of those rockers, I vote Harland Sharp. I dont know much about the Hughes stuff, Im betting they are made by a similar company as the Indy stuff (Dove) but not sure. I would look into T&D Machine. They might be priced close to the HS stuff and they will take the abuse of high spring loads. What cam do you plan to run? And do you think the future will call for a upgrade. Its cheaper to but the better rockers the first time, than buying two sets..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#883064
12/18/10 05:13 PM
12/18/10 05:13 PM
Posts: 939 glendora, ca.
Deepockets
glendora, ca.
i went with the t@d's and they are nice. i will have to barly grind the rockers so that they wont interfear with the +.100 retainers.(only a few thousands) also the studs that came with my t&d's and with the heads only are 1/2" long where they thread into the heads. the heads are tapped to a full 3/4" and i'm going to have to buy some longer studs for that.
[Re: AndyF]
#883066
12/18/10 05:54 PM
12/18/10 05:54 PM
Posts: 8,165 Left Coast
BobR
Left Coast
The T&D stuff is really nice. They make some excellent parts.
You want the best? T+D or Jesel. Harland Sharp is OK. The rest is junk IMO.
[Re: BobR]
#883067
12/18/10 08:23 PM
12/18/10 08:23 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Our cams are between .660 and .720. Its a 497 bracket engine that won't see more than 7500rpms. We want things to last and perform well. I don't know if Jesel is quite in our price range but we may hold up a bit and get the HS or T&D stuff.
Are the T&D rockers around the same costs as HS? About $75 per rocker?
[Re: Deepockets]
#883071
12/19/10 11:19 AM
12/19/10 11:19 AM
Posts: 3,441 Mo.
supercomp
Mo.
i went with the [Email]t@d's[/Email] and they are nice. i will have to barly grind the rockers so that they wont interfear with the +.100 retainers.(only a few thousands) also the studs that came with my t&d's and with the heads only are 1/2" long where they thread into the heads. the heads are tapped to a full 3/4" and i'm going to have to buy some longer studs for that.
What installed height?
[Re: Bob_Coomer]
#883075
12/19/10 01:20 PM
12/19/10 01:20 PM
BradH
I think anyone considering the Harland Sharps for Victors should mock up some HS rockers on those heads first before dropping the $$$ on them. It wouldn't surprise me if their longer distance between the shaft c/l and roller tip c/l puts the sweep pattern too far towards the exhaust side of the valve tip. HS rockers are also significantly heavier than most other brands from what I've seen weighing them, and a good chunk of that weight is hanging over the valve end of the rocker, too. IMO, they could use a serious re-design to streamline their Mopar rockers' bodies. As always, just my ... Plenty of people on here absolutely love HS rockers and seem to get a case of heartburn when I express these particular opinions on their products.
[Re: moparlifer]
#883077
12/19/10 02:01 PM
12/19/10 02:01 PM
Posts: 5,080 organ
maximum entropy
organ
not intending to hijack, but will more than .650 offset work?
[Re: maximum entropy]
#883078
12/20/10 06:32 PM
12/20/10 06:32 PM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
when I was in the market for rockers the HS were more than T&D machine...GO with the T&D. call and talk to T&d and buy them from dougherbert.com
[Re: moparlifer]
#883079
12/20/10 07:28 PM
12/20/10 07:28 PM
Posts: 284 Louisiana
kzinge1
Louisiana
Go only with the Harland Sharps .650" offset or the T&D's. Hughes does not have near enough offset requiring a lot of grinding on the pushrod tunnel on the side of the intake port and the bottom of the heads. Saves a lot of agravation.
Had this problem with my Hughes rockers, I have 5/16" pushrods too. They are a nice setup, just require some more work.
