Re: dash removel
[Re: prairiechicken1]
#88301
07/14/08 01:52 PM
07/14/08 01:52 PM
Posts: 2,766 Appleton, Wisconsin
rtmike
Appleton, Wisconsin
You can take it out pretty much whole, but the windshield needs to be out. There are about 4-5 screws holding the dash in that are under the lower part of the seal.
Its not primer its perma gray.
Re: dash removal
[Re: rtmike]
#88302
07/14/08 01:57 PM
07/14/08 01:57 PM
Posts: 4,764 near Port Huron, MI
Paul
near Port Huron, MI
and one behind each kick panel. Just loosen the lower ones first, then take the top ones out and the dash will swivel down, allowing access to disconnect all the wiring and HVAC stuff without having to lie on your back.
