Re: Get into the 5's.....
[Re: MR_P_BODY]
#882026
12/20/10 11:05 PM
12/20/10 11:05 PM
Quicktree
lol if i dont atleast i'm havin FUN,O yea my cuda has a 8.50 cert cage,and it actually has cert 5pt seat belt,and a drive shaft loop and so on and so on lol
LOL... from the way you were talking it didnt even have a roll bar
thats what I was thinking
[Re: gearjammerdart]
#882027
12/20/10 11:19 PM
12/20/10 11:19 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
Still wanna hear more about the 417ci small block!!
417" W8 heads built by Shadydell Speed Shop. Fogger by Monte Smith.
Donald
Sounds sweet, I'd love to build something like that one day.
[Re: Devilbrad]
#882028
12/20/10 11:30 PM
12/20/10 11:30 PM
Posts: 2,495 Richmond , Virginia
BEEQUIK
Richmond , Virginia
Donald
[Re: Devilbrad]
#882030
12/21/10 12:32 AM
12/21/10 12:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Oh, that's hot. What are the smaller outside lines from the heads? Oiling for valvetrain or coolant return?
Coolant lines
[Re: Plumb Wired]
#882032
12/21/10 01:52 AM
12/21/10 01:52 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
I don't want any bad info. out there so to set the record straight the 417 W8 in gearjammerdart's car has gone 5.30 @ 132 on a 36 nitrous jet @ 3200 pounds. Ladder bar, Bob's ProFab front end, Liberty Equalizer trans. with a single disc clutch. Oh yeah this ET was at our home track, Motor Mile Dragway, Radford, VA. DA is usually 3500-5000ft.
Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#882033
12/21/10 08:44 AM
12/21/10 08:44 AM
Posts: 1,629 pa
572charger
pa
i've run 5.70s at 125mph at 3910 lbs on et street 30x12.50 572 pump gas hemi on a 250 hp fogger with ss leafs 002 003 , frame connectors, stock chassis, certified to 8.50 cage, mini tubbed to the uncut frame rails, stock factory dana 60 and factory posi from 1968 with moser axles !! :
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: Plumb Wired]
#882034
12/21/10 10:35 AM
12/21/10 10:35 AM
MR_P_BODY
Coolant lines
The lines below the valve cover rail are oil drainback lines to the oil pan. The lines under the intake are coolant lines.
Mike Gray
I never even noticed the drain lines
[Re: Plumb Wired]
#882036
12/21/10 11:50 AM
12/21/10 11:50 AM
Devilbrad
Pacifica, CA
Coolant lines
Mike Gray
I knew they were too high on the heads to be coolant lines. Thanks for explaining.
