Get into the 5's.....
#881965
12/16/10 06:21 PM
12/16/10 06:21 PM
Posts: 319 NC
Tommy383
NC
can any of you guys running 5's with a stock chassis car post up your specs? Im working with a 68 valiant, and starting to build a 4.25 stroke RB. Looking for ideas to gain some time. Thanks in advance!
Re: Get into the 5's.....
[Re: Tommy383]
#881966
12/16/10 06:23 PM
12/16/10 06:23 PM
Posts: 2,449 nc
earthmover
nc
[Re: Tommy383]
#881972
12/16/10 08:14 PM
12/16/10 08:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
At 5.7 thats like a 8.90 in the 1/4 which will require a full cage so you might as well build a chassis
[Re: BB70DUSTER]
#881975
12/16/10 08:53 PM
12/16/10 08:53 PM
Quicktree
I plan on running in the 5's without a cage...
better not go to a track theres plently of 5 sec ricers on the street
[Re: BB70DUSTER]
#881977
12/16/10 08:59 PM
12/16/10 08:59 PM
MR_P_BODY
You might get 1 pass in then they might say... dont come back till you have one... JMO
[Re: Tommy383]
#881979
12/16/10 09:54 PM
12/16/10 09:54 PM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
I would be putting a cage in it for sure. Just curious as to if anyone is running these times without a full tube chassis, and what kind of motor they are running.
Hopefully I am there next year. My car went 6.33/9.80 1.54 60 ft with pump gas and ez efi fuel injection. Then I went with xfi injection setup because the ez efi was ok wot but street driving my motor was to much for it to work with. With the xfi I went 6.14 in the 1/8th with a 1.43 60 ft, and my fuel energy numbers were on the rich side wot. I installed a flex fuel sensor after I went to the track and the e-85 was .76 fuel energy instead of .68 like I figured it was so I was running rich down the track. I figured it could have went 6.0x somthing, but now I am getting a set of 572-13's so we will see next year if I get into the 5's. I am sure if I changed gears from 3.23's to 3.73 I would pick up some as well. But right now just lots of torque and highway gears.
[Re: BEEQUIK]
#881981
12/16/10 10:34 PM
12/16/10 10:34 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
http://www.youtube.com/watch?v=kxm-NTSOc1sthats a 6.12 pass at over 3600 lbs thru exhaust on a small shot. the NOS only picked me up .13. it was really fat plus i pulled lots of timming because it was on pump gas 493, ez heads, tunnel ram, roller cam, six pack, caltracs and monos, 4.10, 9" vert 4 point roll bar lose 500 lbs from where i am and its on
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
