Re: Is 23 to 18 spline posible?
[Re: JohnRR]
#881914
12/17/10 03:16 PM
12/17/10 03:16 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Why the **** do YOU care ?
Because I'm a caring person !!
[Re: Stanton]
#881915
12/17/10 03:19 PM
12/17/10 03:19 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
I'm finding that one hard to believe
[Re: JohnRR]
#881917
12/17/10 03:36 PM
12/17/10 03:36 PM
Posts: 4,285 Ohio
64dodge572
Ohio
the only output shaft that changes are the old short shaft A-body 833 trany that uses the small spline count output shaft like a 904 auto trany but the rest uses the same 30 spline 727 style one and newer short tailshaft A-body 833 also uses the 30 spline 727 style!
No this is not true , all the iron case 833 I have had were all 30 spline , only 904 sized A body trans I have seen is the alum OD case trans .
John- 66-7 A body trans was 26 spline (904) output except the 67 383 cars.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#881919
12/17/10 07:08 PM
12/17/10 07:08 PM
JohnRR
U.S.S.A.
Didn't know that , thanks for that correction.
[Re: eds dart]
#881921
12/20/10 01:52 PM
12/20/10 01:52 PM
Posts: 2,431 USA
SSAAHemiFan
USA
thanks for your post edssart. I have a b-body 18 spline and I want to build a A-body 18 spline for my barracuda. I was hoping with Jamie's new trans coming out that people will start getting off there original parts.
[Re: SSAAHemiFan]
#881922
12/20/10 01:56 PM
12/20/10 01:56 PM
JohnRR
U.S.S.A.
All you need is a 23 spline A body trans to make the swap .
The 18 spline market bottom falling out isn't going to happen with the release of the new Passon 5 speed.
[Re: cudaman1969]
#881924
12/20/10 03:08 PM
12/20/10 03:08 PM
JohnRR
U.S.S.A.
why don't you just use the long tail shaft trans (18 spline) in the a-body and use the 727 drive shaft? that way you're not butchering anything and can always change it back at a later date.probably get all your money back too.
Then you have to rig up something so the shifter comes out in the right place, my car is a 4 speed already so I have no need to change the driveshaft. I just had to find a good a body mainshaft , I have 2 B body hemi trans with a broken ear on the case so I bought a Passon Aluminum case and tail.
