Re: Street / Strip guys running ET Street Radials.... [Re: MPerry] #881853
11/24/13 08:04 PM
11/24/13 08:04 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
I find i can get about 30 passes and 1500 miles before they go away for me even though i still have some grooves.
Re: Street / Strip guys running ET Street Radials.... [Re: TheOtherDodge] #881854
11/24/13 08:35 PM
11/24/13 08:35 PM
jersey
Spaceman Spiff Offline
jersey
american racer tire, used to be McCreary's.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Street / Strip guys running ET Street Radials.... [Re: SpareParts] #881855
11/24/13 08:41 PM
11/24/13 08:41 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
They won't last as long with a spool, it scrubs the tire and the side wall doesn't give like a slick.
I second that, after swapping to a spool my last set of M/T's got finished off pretty quick. I run regular street tires then swap when I drive to the track now. I will say I've got quite a few street miles and passes out of my Hoosier pro drag radials, I even bought them used at a X275 race
Re: Street / Strip guys running ET Street Radials.... [Re: SLOW67] #881856
11/24/13 09:38 PM
11/24/13 09:38 PM
9secondPhil use the M/T ET Street Radials, he found out that they have 1/2 the rubber left on the casing after the center tread is gone He would run them until the cords started showing, I did the same on my ET Street Radials and the my car ended up 60 footing better on a good track after the car got the tires worn in so the center grooves where gone He sent me some pictures of his on the side grooves, those tires would hook well until almost all of the side grooves where gone
Re: Street / Strip guys running ET Street Radials.... [Re: Cab_Burge] #881857
11/24/13 09:51 PM
11/24/13 09:51 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
That's good info to know!
I saw this thread and saw that I replied to it 3 years ago... and just now retired that set of ET Street Radials. They went close to 3,000 miles on my ride. Driving around lately on regular street tires has just driven home how much good they did do. Buying another set soon!
Re: Street / Strip guys running ET Street Radials.... [Re: Duner] #881858
11/24/13 11:44 PM
11/24/13 11:44 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Good info here, I have always run the et street bias plies, but making the switch to radials for better street handling.
I will say I'm not impressed with street grip, but I've only had the car out in the cold a few times...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Street / Strip guys running ET Street Radials.... [Re: OUTLAWD] #881859
11/25/13 01:19 AM
11/25/13 01:19 AM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
Just pulled this thread up and realized it was mine from a few years ago. The ET streets are still in great shape, but they haven't seen many street miles, as I drive on street tires for the most part and just put the ET Streets on for track days. To further skew the results, the car has seen less than 20 passes in the past two years. Now that I think about it, I might throw them on just to go with the "strip" part of the Street / Strip look for a while, as they're mounted on black steelies (the car now rides on black spoked torque thrust style wheels).
Edit: Oh, and by the way, the car dead-hooks with them (255/60's) and 60's @ 1.63.
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881860
11/25/13 10:06 AM
11/25/13 10:06 AM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
I bought 295/55 ET Street Radials for the Road Runner in 2011, I've driven them for three Drag Weeks, including driving the car from Indiana to Kansas and back in 2011. Total milage is probably about 5000 miles, probably 40-45 passes total. Also driven a few times in some pretty heavy rain and on wet roads, albeit cautiously and with some pucker factor by the driver, I never had any wet traction problems. With smaller (235/70) T/A radials on the front, the car drives nicely on the street. The tires are now almost down to the wear indicators. I do short burnouts to conserve the tires. Hook is OK, but my chassis setup is basically stock (crap), so my 60 foots are about 1.7X running about 11.5X @120+.
Scott
