Re: Vintage " Hustle Stuff " 340 Tri-Y headers A-Body
[Re: Hardcharger65]
#881641
12/16/10 02:22 PM
12/16/10 02:22 PM
Posts: 2,578 sweden
1Fast340
sweden
beutifull! glad they come to use! thats something that realy should be remade, and i gues they got all the tubes above the steeringcenterlink aswell! there is just one thing that looks alitle odd,is there enough space for the oilfilter? my gues is that that design would have a big benefitt when it comes to groundclearance! what kind of tubesize are they BTW?
[Re: 1Fast340]
#881642
12/16/10 06:20 PM
12/16/10 06:20 PM
Posts: 27,465 So Cal
autoxcuda
So Cal
... there is just one thing that looks alitle odd,is there enough space for the oilfilter? my gues is that that design would have a big benefitt when it comes to groundclearance!
Only think I can see is that the width of all those tubes would run into something. Like that's double-wide down there.... Clutch linkage, frame rail, bellhousing width, etc, etc ???
someone stop me from cutting up these TTI's, please...
[Re: Golden-Arm]
#881644
12/16/10 08:14 PM
12/16/10 08:14 PM
autoxcuda
So Cal
i'd imagine they fit perfectly, if they came from mopar. need to let someone measure them, for copies, before ya both them on though.....
Ok, it sort of looks like 2 of the pipes come together before the bottom where the other two come together?? So there's really not 4 pipes wide on the end of the headers were the 2 to 1 connectors go??
[Re: autoxcuda]
#881645
12/16/10 09:38 PM
12/16/10 09:38 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Those look like they would fit an early A as the #3 tube comes out and over, not down like most. I already grabbed the pics to put in my design folder...FYI Early-A motor mount closer to the front axle centerline so later headers always hit the centerlink and tie rods. Or later longer wheelbase A models moved the front suspension farther forward (probably more accurate)
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: Mattax]
#881647
12/19/10 02:15 PM
12/19/10 02:15 PM
autoxcuda
So Cal
Very cool. Let us know how well they fit and post some photos please.
Any part numbers or identifying marks?
Autoxcuda - Anything in your collection of early catalogs?
I only go back to the 76 DC Catalog. This from a 60's to early 70's Hustle stuff catalog supposedly. I'm going to look now at http://www.hamtramck-historical.com/library.shtml they have some Hustle Stuff catalogs online there.
[Re: autoxcuda]
#881648
12/19/10 02:43 PM
12/19/10 02:43 PM
autoxcuda
So Cal
The 65, 68, and 69 HiPo Catalogs don't show headers. Do any of these seem to be Tri-Y type header. Maybe 3549761 ??? HardCharger65, are you sure these were from Hustle Stuff? Wonder if they could be a Hamburgers part or some header company back in the day. Any part numbers faintly stamped on the flanges?? 73 Hustle stuff Here's the 71 Hustle Stuff...
[Re: Hardcharger65]
#881655
01/07/11 07:23 PM
01/07/11 07:23 PM
Posts: 1,411 Southern Michigan
Dartman440
Southern Michigan
Hi Ed, These are super rare. I have one other set. I bought these from Al Nichols. Unfortuantely he has passed us on in Mopar Heaven. He was Chryslers Carb and small block Guru.I met Al at Gary Rollins Rapid Transit Car Club Swap Meet on Strathmoor in Detroit.Joy Rd. And Chase. Al did all the hot carb set ups from the mid 50's on up. He was a great guy and had a ton of rare and unusual Mopar parts. He loved 340's. He had a huge garage near Waterford, Pontiac area of Michigan. It was wall to wall with carbs, 340 blocks, heads, everything imagineable.He had lots of W2 heads, intakes etc. Nascar three barrel carbs, Six packs up the ying yang.Thermo Quads. AVS,Holley's etc. I bought a lot of parts from Al.I even have an NOS 69'Center Grille Bright Eye for a "C" body that was outlawed by the goverment mid year because it was labeled as too bright.It used a halogen bulb with a magnified lense.I bought that from Al also. I bought these headers from Al back in 83' These are tuned Tri Y headers. Each tube is the same length. These are for an A body 1967 to 1976. Manual steering is a must. The colletor is an adjustable length you would cut off an inch at a time slide it back in and see how much tenths your car would pick up in the qtr mile. Al told me these are Hustle Stuff Tri Y's and are extremely rare. They did not sell well because they were too expensive. If I remember correctly they were made by Hedman he said. They worked great on the 340 that they Dyno'd. They were made also for Super Stock legal 340 heads.They picked up the most cutting off three inches with the set up they used. They have standard 340 X head exhaust ports. Not W2 or any kit car head. Kit car headers came out to the sides immediately. Al did fine tuning on carbs and dist. curving.Als favorite car that whupped a lot of ass on the back lot of the Hamtramck headquarters and facilities was a 1970 Buick GS Stage 1.15" Steel wheels with dog dish caps. He ordered it new. Triple green Auto on the column. Manual steering. 4:10 posi. He tweaked the Rochester Carb jetted and different metering rods. Curved the dist. The car went 12:69's. The used his car to test new camshafts and different mods to the 70 Six pack and hemi cars.They never beat the GS. He still had it when he passed away. It had 19,000 original miles.He even kept it thru his divorce. Well there you have it. The source were they came from and waht they are. I never had the guts to use them because they were so rare. They hung in my basement for years. The set I have left is the set they dyno'd. Ed has the NOS set. They came red. Happy New Year.
[Re: TC@HP2]
#881660
01/09/11 03:01 PM
01/09/11 03:01 PM
Posts: 304 Ohio
LS-300
Ohio
Now that they have been "found" I wonder what it would take to recreate? Are these what the Dougs are based on?
1979 Chrysler 300
1968 Barracuda project
[Re: LS-300]
#881661
01/09/11 03:13 PM
01/09/11 03:13 PM
autoxcuda
So Cal
I think we should see how they fit first.
I doubt Dougs or any others were based on these. Only tri-y for SB's I've heard of. The rest seems relatively different.
