Re: back brace
[Re: plycuda]
#881058
12/15/10 07:37 PM
12/15/10 07:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Both parts are in a set... otherwise if it was only a side it would ask LEFT or RIGHT(they are different EDIT its real easy to make them from 2 X 3 tubing and a set of dividers and a band saw(I make my own)
Re: back brace
[Re: DemonDust]
#881061
12/16/10 11:37 AM
12/16/10 11:37 AM
Posts: 4,070 Mo.
racerx
Mo.
Not to hijack your thread, but when you weld these in do you have to do it in a jig? I've heard it warps the housing?
In my opinion that would be the best way I've weld a couple with the weld a " method and switch to prevent warpage and to seem not to get around it.
Re: back brace
[Re: racerx]
#881062
12/16/10 11:40 AM
12/16/10 11:40 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
So if I'm reading this correctly you stitch welded an inch at a time and alternated areas? And it still warped the housing?
Re: back brace
[Re: DemonDust]
#881063
12/16/10 11:44 AM
12/16/10 11:44 AM
Posts: 4,070 Mo.
racerx
Mo.
That's correct.and always seems to have to cut the ends off and re weld the backing plates in a jig
Re: back brace
[Re: tboomer]
#881064
12/16/10 12:12 PM
12/16/10 12:12 PM
MR_P_BODY
There we have it!! Mike is retired witha new shop...I can see it now...Riff-Raff Engineering!! How bout it,Mike!!
Been that way for a while... fab work and welding and working on my cars keeps me going.... I stitch weld the brace then add the ends
Re: back brace
[Re: Cab_Burge]
#881068
12/16/10 05:38 PM
12/16/10 05:38 PM
Posts: 142 Maryland
Sick 660r
Maryland
If the rear becomes warped what can you do to fix it?
2000 dakota
418 magnum
paxton novi 2k
T56
Re: back brace
[Re: DemonDust]
#881069
12/16/10 06:36 PM
12/16/10 06:36 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Yes, but first keep in mind a jig is mainly for ease of welding and to verify proper alignment, no jig will prevent by itself warping. And if it warps a reasonable amount, first fix is to cut off housing ends, realign, and then reweld carefully.
Re: back brace
[Re: Sick 660r]
#881070
12/16/10 06:43 PM
12/16/10 06:43 PM
MR_P_BODY
A press and or a torch with a rosebud and a press
Re: back brace
[Re: DemonDust]
#881071
12/17/10 05:18 AM
12/17/10 05:18 AM
Posts: 660 San Diego
formula S
San Diego
Anyone have pics of how they jig up an 8 3/4?
I used a 10" I-beam about six feet long and a piece of 3/4"x 3"x 6' flat bar to make my fixture. I took the flat bar and set it on top of the I-beam and welded it so it was 3" high, then I set the housing face down, you will have to notch it common to the gasket surface. Next you need to clamp it to the fixture then tack it in several places, now remove your clamps and get your back brace, fit it, tack it, and weld it, no need to stitch it ,just let it cool in the fixture before you remove it, it wont pull if you do it this way
Re: back brace
[Re: jcc]
#881072
12/17/10 05:38 AM
12/17/10 05:38 AM
formula S
San Diego
The fixture I made works really well and prevents any warping at all. I have seen housings that were warped, the axles wont go in straight because the bearing dosent line up with the housing, not the case with this method. The I-beam and flat bar are really heavy duty and dont see any heat, so no fixture warpage.
Re: back brace
[Re: racerx]
#881073
12/17/10 02:56 PM
12/17/10 02:56 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Most people don't have a jig. I didn't when I did my brothers. I did and inch or 2 at a time and moved around. No warpage at all.
Re: back brace
[Re: BobR]
#881075
12/18/10 12:56 PM
12/18/10 12:56 PM
Quicktree
I have done more than a few, if the axels are in they kind of act like a jig imo. I fully let the small welds cool before doing more. they may not be perfect if they were put on a jig but they have never caused any problems.
