Re: To use wheel spacers or not, that is the question.
[Re: Challenger 1]
#881016
12/16/10 09:44 PM
12/16/10 09:44 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I did the same thing to get my car lower.I used the Mr.Gasket aluminum wheel spacers.They have 4 different thickness'. They are inexpensive and do the job. No need for $40-50.00 spacers.
OK I'm not afraid to stir the pot!!
I think a race car thought out using wheel spacers is well, chessey.
Wheel spacers should avoided at all costs, especially cheap aluminum ones. They can crush, they will eventually and then you got loose lug nuts.
Just because a lot of guys use them don't make it safe or right.
A 1/8" should be the maximum thickness considered for wheel spacers.
It adds weight to a car also which is not what you want on a race car.
I agree spacers should be avoided when possible, but why would a 1/8" spacer be any different than a 1/4" or thicker? You would really have to put more torque on studs than they would hold to crush them, No , the only way to crush them would be with a press. Torque properly and you'll be OK.
[Re: rowin4]
#881018
12/16/10 09:50 PM
12/16/10 09:50 PM
Challenger 1
Cincinnati, Ohio
Because the thickest MW sells is 1/4"If they even sell em anymore. I just looked and these MW spacers are 1/4", sorry my bad. These were the thickest they would sell me years ago. I never used them. Brett at MW is who educated me about wheel spacers, who did you learn from gregsdart?
Someday when you make enough HP and experience tire shake, that is what will cause wheel spacers to crush and long studs to stretch.
[Re: Challenger 1]
#881019
12/16/10 09:53 PM
12/16/10 09:53 PM
Posts: 4,085 Indiana
W5Duster436
Indiana
Quite a few spacers here? I guess those are for 11/16 studs though..
'70 Duster - SDSS 436 W5 4spd (Gone) '71 Dodge D100 '70 Dodge W100
[Re: gregsdart]
#881021
12/16/10 11:24 PM
12/16/10 11:24 PM
KOS
Gee, i guess Mark Williams is all wet then. He sells a lot of spacers, several widths. Guess I better reconsider twelve years worth of running them,,,,,,,,,, WHEN PROPERLY USED, THEY ARE FINE! ON THE OTHER HAND, NO SET UP WILL LAST WITH IMPROPER TORQUE OR MAINTENANCE. I trust MWs reputation just a bit more than anybody posting on this thread! They have a tad more experience.
ive ran them for yrs and lots of other guys i know too(serious cars)never had or seen an incedent with them.
[Re: W5Duster436]
#881022
12/16/10 11:30 PM
12/16/10 11:30 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Mark Williams lists spacers in 1 inch, 1/2 inch and 1/4 inch. I just got off their web page. Search spacers. As far as who I learned from, personal experience putting one heck of a lot of torque through them for as I said, over twelve years. I run a torqueflite. The starting line hit is brutal to say the least. If they were not safe to use, MW wouldn't list them. Don't know who you talked to, but he obviously doesn't agree with the head of the company. One last thought. Ever wonder why a dual disc clutch has about twice the holding power of a single? Same principle. You just need to be sure the pressure is there to provide the proper friction. With that being said, spacers will provide even more stength if used properly. Improper torque on the studs will allow slippage and the leverage on the studs is higher than with no spacers. So like i said earlier, use them properly, or not at all.
[Re: KOS]
#881023
12/16/10 11:59 PM
12/16/10 11:59 PM
Posts: 2,177 ill
dennismopar73
ill
every company sells something that they probably shouldnt be but sell it non the less, ie compression fitting for brake line comes to mind real quick, and mark williams does have alot of experience with rears than most like i said in previous post do what others say . there are just some thing that i wont do, so doesnt matter but this board is full of really good info
[Re: Challenger 1]
#881025
12/17/10 12:50 AM
12/17/10 12:50 AM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
It's not a race car, a pair of 3/8" spacers may add 1 1/2#, total
[Re: 74DusterP457]
#881027
12/17/10 10:34 PM
12/17/10 10:34 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
[Re: justinp61]
#881029
12/18/10 12:17 AM
12/18/10 12:17 AM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
With all that extra weight you will need to find more power for that pound and 1/2 at the rear... I have a 4,000lb street car that I used spacers in for years...Raced alot and NEVER had a problem. My car 60ft'd 1.52-3 on 10inch tires and had plenty of street miles too...
