Re: knocked 43# off my rear end... [Re: Mopar-Al] #880859
12/15/10 08:34 PM
12/15/10 08:34 PM
Arizona
Chris'sBarracuda Offline
Arizona
you sure the drum weight was 33.5 total each side and not total? I just weighed mine on a scale (one side) and it showed 18 lbs. I didnt weigh the emergency brake lines. Great you did loose the weight tho
That was drum and backing plate..
When I switched to disc all 4 wheels, years ago (Aerospace) I knocked off just over 100#..
Chris..
Re: knocked 43# off my rear end... [Re: dartman366] #880860
12/15/10 08:42 PM
12/15/10 08:42 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I lost 45 lbs. off mine swapping to Aerospace 4-piston from 11" x 2 1/2"
You should notice the weight difference.
100 lbs. off of your car?
I'm going another +.020" on the 340!
Re: knocked 43# off my rear end... [Re: S/ST 3040] #880861
12/15/10 10:36 PM
12/15/10 10:36 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Wow, Bob. You never sit still.. Still waiting to get the pics off of my camera.. Way to go, Billy. I wonder how differnt it will effect the cal trac settings? Might have to weigh and re-set them up? Thanks for the pics.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: knocked 43# off my rear end... [Re: sunroofgtx] #880862
12/15/10 11:13 PM
12/15/10 11:13 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Boy does that tittle leave the door wide open
I picked up quite a bit when I swapped to 4 wheel discs and a spool. I really didn't get it at the time till someone mentioned that around every 10#'s of rotational weight you take off is liking taking off 100#'s of dead weight.
Not sure how true that is but that's what I heard.
Re: knocked 43# off my rear end... [Re: WILD BILL] #880863
12/15/10 11:44 PM
12/15/10 11:44 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
So do you have to get a smaller seat??? Oh wait it's not THAT rearend
Looks good Bill and I'm sure you will be quite happy on how it stops. Losing all that weight is instant go faster
Russ
Re: knocked 43# off my rear end... [Re: max_maniac] #880864
12/16/10 12:39 AM
12/16/10 12:39 AM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
That thing will fly with your new B.B. motor....errr
Re: knocked 43# off my rear end... [Re: Chad Bittle] #880865
12/16/10 01:40 AM
12/16/10 01:40 AM
Pittsburgh PA
Eric Offline
Happy Birthday Eric  Offline
Pittsburgh PA
I'm hoping I can do the same to the Arrow some time also....it's such a slug a 2130#.. ...I'd love to knock the Dana drums and factory Mustang II stuff to the curb and lose a tenth..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: knocked 43# off my rear end... [Re: Chad Bittle] #880866
12/16/10 02:36 AM
12/16/10 02:36 AM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
Chad, it going to fly with out it too.
wo23coronet,cannot answer that, the green bearing has a retainer ring around it that look's like a circlip that retains it and the bracket's are made for that.
Hookd, it actually stopped quite well but it started to get the stock front rotors hot to the point they started to turn black in spot's and were starting to warp them from the heat and at the end they would rumble the car when you applied them, turning the disc's would of corrected the out of trueness but I was afraid of heat stress and eventually cracking or worse.
Butch,,,both, but I feel safer now.
Russ, as long as I can keep going with my diet I may have to add some padding to the seat in the car, lost about 12# so far.
Re: knocked 43# off my rear end... [Re: Mopar-Al] #880867
12/16/10 02:51 AM
12/16/10 02:51 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
That was 1 drum and backing plate with brake shoes and hardware or 67# for both sides minus 24#total added back on for the Strange stuff, 43# weight loss,,the C barge drums are 21.5# each.
Re: knocked 43# off my rear end... [Re: dartman366] #880868
12/16/10 03:44 AM
12/16/10 03:44 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Those big drums are HEAVY! I knocked almost 66# off the front of mine going from those big drums to an Aerospace setup. Total weight of the entire Aerospace kit in the box was 27lbs
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: knocked 43# off my rear end... [Re: Irun5snd8th] #880869
12/16/10 08:59 AM
12/16/10 08:59 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
That's an awesome weight savings with the added benefit of safety. I am switching from four wheel drums to a race Wilwood setup on my Dart Sport. Also will be going to Bob's frontend at the same time!
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: knocked 43# off my rear end... [Re: Jacob Pitt] #880870
12/16/10 10:00 AM
12/16/10 10:00 AM
gregsdart Offline
gregsdart  Offline
A big win/win/win move.
Big stopping safety margin.
100# is a big amount of weight reduction.
Rotational weight will probably double the ET reduction?
Re: knocked 43# off my rear end..."update" [Re: gregsdart] #880871
12/16/10 01:54 PM
12/16/10 01:54 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
did a little more checking and weighted some front end stuff and came up with an additional saving's of approx 80# over the old 73-76 front end components, this includes brakes,spindles,lca and strut rod,,looks to be around 120# total weight off the car
Re: knocked 43# off my rear end..."update" [Re: dartman366] #880872
12/16/10 03:02 PM
12/16/10 03:02 PM
ohio
all spooled up Offline
ohio
what you going to use for strut rods and lca
Re: knocked 43# off my rear end..."update" [Re: all spooled up] #880873
12/16/10 03:31 PM
12/16/10 03:31 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
tubular lower and aluminum strut.
Re: knocked 43# off my rear end..."update" [Re: dartman366] #880874
12/16/10 04:31 PM
12/16/10 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a BIG weight savings Bill
Re: knocked 43# off my rear end..."update" [Re: dartman366] #880875
12/16/10 05:57 PM
12/16/10 05:57 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Dang Bill.......You keep it your gonna need a chute next
Re: knocked 43# off my rear end..."update" [Re: 340RICK] #880876
12/17/10 02:34 AM
12/17/10 02:34 AM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
But that would add weight back on. Just trying to get where I want to be, plus it make's the car safer, pretty good trade off for some un needed pound's.
