Page 5 of 5 1 2 3 4 5
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: SomeCarGuy] #880707
12/17/10 11:35 PM
12/17/10 11:35 PM
USA
b54406barrel Offline
USA
You must be in training for message board mercenary warfare then. What is the going rate for "involvement" in a conflict these days?
I do know how to spot a forged crank after staying at Holiday Inn Express.
No, bored till my flight leaves in a few weeks for the Marshalls.
It's quite easy to do in an assembled engine removing the damper, with a tuning fork. If your old enough.
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: 69CoronetRT] #880708
12/18/10 12:24 AM
12/18/10 12:24 AM
Massachusetts, USA
MASSMOPAR Offline OP
Massachusetts, USA
Or maybe just let the car rot in a field somewhere. Cause everyone wants 100 point mega buck car.
No..I'd love to have a nicely done driver quality four speed R/T. It's just that the little things do make a difference and when you look at what could have been done very easily with little time or effort, and wasn't done, it makes you wonder about the quality of work on other things. For example, a chrome breather cap is a distinctive detail, easy to get and doesn't cost that much. Since it wasn't swapped, it's a glaring detail that sticks out. Luckily, this is an easy thing for the new owner to fix.
Painting the bezels around the stripe wouldn't have taken that much more time or effort to do right the first time. Since they weren't painted, it's a glaring detail that sticks out. This could be fixed by the buyer but why should they have to?
Emblems and a stripe? The body color through the stripe is a detail I love about the 69 R/T. the emblem on a stripe delete car is not centered above the bezel.
The same is true for the black out behind the grille. It wouldn't have taken that long to shoot the support black. Again, this could be done by the new owner but why should they have to go back in and do it? It would have been so much easier to do when you had things apart.
There are some other small things that could have been done differently and no one item is a deal breaker for a nice driver but things like this do add up to a guy like me. It makes me go...hmmmm....if they didn't take the time to do the little stuff, did they really take the time to do the big more expensive things like the engine, tranny, rear, body work, etc, correctly? Getting some of the details right, and they do not have to be to 100 point specs for a car like this, do pique interest and add value to a sale.
And, yes, you should save every 69 Coronet R/T you find rotting in a field.
Appreciate your comments...points well taken.
Saving grace - 9 propective buyers out of 10 would not know about chrome breather, black out, bezel paint, R/T emblem alignment etc. etc etc.
Could it be better - absolutely.
Thanks. Where were you couple months ago.
BTW are you saying the bezels should not be painted?
70 Road Runner 528 HEMI 4sp FY1 70 Road Runner 440+6 V-Code AG 4spd EV2 69 R/T 4 Spd Dana 3:54 AG Vert B5 69 R/T 4 Spd Dana 3:54 AG X9 V1X V8R-WORKING 69 R/T Auto/Console 8.75 SG Vert R/T B3 08 Challenger 1st Edition Hemi Orange 69 Super Bee 4 Spd 8.75 SG AG F8
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: 69CoronetRT] #880709
12/18/10 12:47 AM
12/18/10 12:47 AM
Massachusetts, USA
Massachusetts, USA
No need to wonder - check out the pictures on EBAY
and point out the many small omissions - much appreciated. Thanks
http://www.vuvox.com/collage/detail/0337e40c94
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: MASSMOPAR] #880710
12/18/10 01:27 AM
12/18/10 01:27 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
The bezels are painted black or white to match the stripe or body color if the car came stripe delete. The bottom pictures shows the offset of the emblem to the bezel.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: MASSMOPAR] #880711
12/18/10 02:09 AM
12/18/10 02:09 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Very true. But what will the opinion of the buyer be toward YOU and your work when the new owner takes this car to their first cruise in or car show and run into that 1 out of 10 person that points out these things? Will they think highly of you and the 'restored' car they purchased? Doing the small things correctly when it is time and cost efficent to do them go a long way.
RE detail pictures. This car was intended to be a driver so I understand compromises were made. Certain details may have been intentionally omitted or added after the pictures were taken. (for example various stickers) There were variations between plants on certain things that may or may not appear on this specific car. If you don't know those variations going in or they are not apparent on the car, researching the details takes time and money and add little overall value. Certain details do become cost prohibitive if you are trying to make a profit and don't make sense on a driver.
Things like the shifter handle are a personal choice and the "T" handle is very period correct and a common personalization made by owners. This is no big deal to me because it's easily changed if the owner wants to.
I can't tell for sure but it looks like you did not install a fuel vapor separator and I presume the return line. Again, small details that add to the restoration cost and detract from the profit but this is 'one of those things' specific to this model that add up after a while. Would it matter to most people this is missing? Probably not but it would to some.
It appears to be a nice car from the pictures. It's certainly a desireable car but I'd be that 1 in 10 guy that would be willing to pay a little more for more items that were 'correct'. It shows me the shop took their time to do it as right as possible given the parameters they had to work with.
Seeking:
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: MASSMOPAR] #880712
12/18/10 05:23 AM
12/18/10 05:23 AM
Goat Rodeo
drago Offline
drago  Offline
Goat Rodeo
Hi massmopar -
do you bite?
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: 69CoronetRT] #880713
12/18/10 06:49 AM
12/18/10 06:49 AM
Massachusetts, USA
Massachusetts, USA
I looked at this car when I received it and decided it was never gonna be a purist dream.
I knew it was a stripe delete car - but wanted a stripe. Slippery slope and unintended consequences to follow... Hindsight: I wish I had just done the stripe without the emblems now that I know emblems were offset that much on a stripe delete. If I went with just a stripe the bezels would have been painted the body color. That won't happen in the future. If I could do it all over again, I would have painted the car F8 and just emblems no srtipe. At least match the fender tag.
Thanks again
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: drago] #880714
12/18/10 06:52 AM
12/18/10 06:52 AM
Massachusetts, USA
Massachusetts, USA
Hi massmopar -
do you bite?
Hi Drago
yes I bite.
Do you suck?
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: 69CoronetRT] #880715
12/18/10 09:04 AM
12/18/10 09:04 AM
Massachusetts, USA
Massachusetts, USA
Soon - I'm tackling this rusty 69 charger project #'s 383 H code 4 speed console T7 ext. T5 int. 2 buildsheets fender tag, 1 owner car.
My intention is to restore to driver quality.
I was thinking of making it an R/T clone.
Now after all, I'm going to follow the buildsheet and resist my personal preferences.
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: 69CoronetRT] #880716
12/18/10 11:13 AM
12/18/10 11:13 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Finally a response from someone that can give information/opinions without the derogatory remarks,criricism and name calling.
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: 62maxwgn] #880717
12/18/10 11:32 AM
12/18/10 11:32 AM
Massachusetts, USA
Massachusetts, USA
Refreshing, clear and thoughtful comments. Changed my mind on few things.
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: MASSMOPAR] #880718
12/18/10 12:31 PM
12/18/10 12:31 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Good call. A nicely done (not perfect, not a mega buck 100 point car but done well) original 383 - 4 speed Charger would be much more marketable than another R/T clone.
BTW if the Charger was built at the St. Louis plant ( G plant ) I'd be interested in knowing more about it as I track cars built at that plant. If you don't already know him, I'd encourage you to contact Chris at the 69 Charger registry if you need a good resource.
69 Charger Registry
Seeking:
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: 69CoronetRT] #880719
12/18/10 12:53 PM
12/18/10 12:53 PM
Massachusetts, USA
Massachusetts, USA
69 Charger Registry
Will do...
The charger is a St Louis plant build "white hat special"
http://www.youtube.com/watch?v=ZZLi7LsHXUc
Re: D440 9 29 02502 ? what do these numbers stand for? [Re: b54406barrel] #880720
12/18/10 06:31 PM
12/18/10 06:31 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
another view
Geez, this is another one of those rough threads! Well, I'm far from a purist but the easy to see & fix ones the VR, wiper motor, radiator cap, m/c cover & probably m/c, too and my 6bbl car came with black plug wires & tan cap. Looks like a neat car.
I hope you guys are kidding because it sounds like school yard trash talk from grown men.
