Re: Tranny Pump Seal Re and Re.
[Re: GwaiiEagle]
#880302
12/14/10 11:16 PM
12/14/10 11:16 PM
RapidRobert
It's your "front pump seal". W a small screwdriver/hammer at JUST THE RIGHT ANGLE so as not to mar the aluminum housing cave the seal inward at various points around the perimeter until it is loose enough to pull it out. Pack the rear of your new seal with vaseline to hold the spring in place then tap it in evenly using something flat around the seal at various points. Be sure to get it started evenly (& keep it even as you go around tapping it) and end up w it it flush w the case. Lube the TC snout w trans fluid
[Re: GwaiiEagle]
#880304
12/15/10 10:30 PM
12/15/10 10:30 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
The seal in your trans now is made of Nitrile "rubber". That stuff is bulletproof. If it is really leaking from there, you have a bushing/hub problem. The new seal you show is made of silicone "rubber". O.E. to be sure on early T.F., but I would not use it. Pat
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: zzyzxpat]
#880305
12/16/10 12:23 AM
12/16/10 12:23 AM
Posts: 964 Nanaimo, B.C.
GwaiiEagle
Mannix
Mannix
Nanaimo, B.C.
Sorry, but this is why I am on this board, what is a Bushing and What is a hub.
You mean a tc hub?
