For his Duster, my son Aaron bought some leaf springs that are supposed to be Super Stock. I'm having a hard time locating replacement bushings with similar dimensions to the ones in these springs when I use the term "Super Stock".
Tell me if these are what is truly considered "Super Stock":
Springs are 2-1/2" wide and have three long leaves and one very short leaf at the locating dowel where the axle mounts.
Front eyes -
1-1/2" inside diameter
1/2" diameter bolt
Rear eyes -
1" inside diameter
3/8" diameter bolt
I was under the impression that Super Stock springs have four leaves on the driver side and five on the passenger side, causing it to be raised slightly higher. These springs look no different than the stock springs on Aaron's Dart Sport.
Tell me what you think,
Jerry
