Re: Self Learning EFI systems with nitrous? turbo? super?
[Re: ahy]
#879363
12/14/10 12:35 PM
12/14/10 12:35 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
[Re: feets]
#879365
12/14/10 02:04 PM
12/14/10 02:04 PM
Mopar_Rich
Sonora CA
I think that going easy on the learning cycles with boost would be a benefit. Don't slam WOT and 40 psi boost into the engine the first time you fire it. Work up to it so the computer can learn. After that, it will have the MAP figured out and should respond like anything else you've programmed.
True for the XFI 2.0, but not for EZ-EFI. The EZ-EFI will not allow for more than a 1 bar map table.
Nitrous? No. I don't like the idea of a dry system even on the LS1s that made it so popular. That's relying on an O2 sensor to correct the mix (I believe). That means the first few batches have already burned. I don't like living on the edge of engine death.
A dry system is better (again, I'm only talking about the XFI system). The XFI does not use the O2 reading when using nitrous to determine the amount of fuel. There is a base nitrous table (based on how much HP is being added) that it uses to immediately add fuel faster than any other approach could do. You have control of whether is goes back into closed loop later after things have settled down, or you can stay open loop. In my opinion this is a very safe way to go since the engine will never see "the edge of death".
[Re: Mopar_Rich]
#879366
12/15/10 01:44 PM
12/15/10 01:44 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I was told they were working on multi-bar map systems for the EZ systems.
As for the nitrous tables you're feeding the computer info and it's assuming the N2O is flowing when triggered. It sould work fine as long as you don't change the N2O pill without changing the tables. I'm still not comfortable with N2O. Something about it bothers me.
