SBM head gaskets #878893
12/13/10 12:01 PM
12/13/10 12:01 PM
Champion City
The Sphinx Offline OP
Champion City
What head gaskets to use with aluminum heads? Fel-pro 1008's?
Re: SBM head gaskets [Re: The Sphinx] #878894
12/13/10 12:06 PM
12/13/10 12:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been running the 1008s for years without any issues
EDIT
if your running high compression then maybe the Cometics
Re: SBM head gaskets [Re: MR_P_BODY] #878895
12/13/10 12:32 PM
12/13/10 12:32 PM
Champion City
Champion City
They work fine with aluminum heads? I've them on iron heads with no problem. Compression is 10.2:1
Re: SBM head gaskets [Re: The Sphinx] #878896
12/13/10 01:21 PM
12/13/10 01:21 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
they have been on my 11.25 cr iron head/ stock head bolt motor for 10 years/10k miles now.
Re: SBM head gaskets [Re: ademon] #878897
12/13/10 01:40 PM
12/13/10 01:40 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I've ran both.. Felpro and the Cometics, both worked on my little 11:1 motor, but I needed a custom thickness this last time out, so I went with Cometics.
They're still in there and they're still holding up well..
Re: SBM head gaskets [Re: Jeepmon] #878898
12/13/10 01:58 PM
12/13/10 01:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
1008s here at a real 13.0:1, 8000RPM, aluminum Batten W2s, studs, low 10s, no problems.
Re: SBM head gaskets [Re: topside] #878899
12/13/10 02:42 PM
12/13/10 02:42 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Almost the same here.
Re: SBM head gaskets [Re: The Sphinx] #878900
12/13/10 03:54 PM
12/13/10 03:54 PM
Champion City
Champion City
Thanks for the feed back everyone!
