Re: Is a .050" quench height still effective?
[Re: BradH]
#878837
12/13/10 11:05 AM
12/13/10 11:05 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
[Re: BradH]
#878843
12/13/10 12:55 PM
12/13/10 12:55 PM
Posts: 5,160 Texas
dannysbee
Texas
I would rather have the tighter quench with 11.00 to one than the .050 with 10.8 to one. I ran a 10.8 to one cast iron head with .038 with a .223 at 50 cam for years on 92 pump gas. Only time I had any problem was when the temp got in the high 90's. You would hear just a little in high gear. Couple gallons of race gas would fix it. With aluminum heads better combustion chamber shape and more cam duration I would think you would be OK.
Getting old just means you were smarter than some and luckier than others.
[Re: maximum entropy]
#878849
12/13/10 02:41 PM
12/13/10 02:41 PM
Posts: 2,128 sweden
sshemi
sweden
i know how much you value my input ( ), so i urge you to keep that quench as tight as possible! i've built several hot street engines with compression ratios close to 11:1, with very good results, as long as the quench is super tight. they've all been between .035 and .039. my personal mill started at .055, and had some issues in hot weather, that were completely ameliorated when i brought it to zero deck. i am the quench nazi because of this experience.
Was that the only change you did???
[Re: Streetwize]
#878852
12/13/10 04:19 PM
12/13/10 04:19 PM
BradH
I'm seeing a pattern here... FWIW, the pistons stick out of the deck .002", so quench will be .038" w/ a typical composition gasket. I haven't assembled the thing, yet. However, I've collected most of the parts already. I don't know if I'll have to band-aid the 11.0 CR w/ a longer duration cam or not at this point.
[Re: sshemi]
#878853
12/13/10 04:40 PM
12/13/10 04:40 PM
Posts: 5,080 organ
maximum entropy
organ
i put in a slightly smaller cam, which would have made the problem worse. i hoped that the improved quench would help the situation (not that it was that bad), and to my surprise, the hot weather pinging has vanished. the car is faster, too btw. 1/2 a tenth.
[Re: moparniac]
#878855
12/13/10 08:16 PM
12/13/10 08:16 PM
Posts: 1,200 UK
602heavy
UK
I also was at 11.12 to 1 in my challenger and I raced on 93 pump gas with that also! with a puny 248/254 @ 50 roller with more than .050 quench.... however The cam was 69 Intake valve closing ABDC..... ever wonder why wallace wants to know this on his dynamic calc? the higher the number the more its bleeds of cylinder pressure...
Does early intake valve closure have a direct bearing regards detonation? , maybe excessive overlap (ex bias) has more influence than we think.. , lots of variables to think about regards valve events.
