when was the last time you checked!! #875269
12/08/10 10:39 PM
12/08/10 10:39 PM
DANBURY CT
fury62 Offline OP
fury62  Offline OP
DANBURY CT
I recently checked my front moroso drag tires, they look brand new with no cracking or dry rot,but they are dated 2000 I'm getting a little leery 10 yrs. going on 11. it's seem like something you forget about. I think it's time for a new set.just wondering how long some other racer keep their tires going for. John
Re: when was the last time you checked!! [Re: fury62] #875270
12/08/10 11:52 PM
12/08/10 11:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I look at my fronts ALL the time(couple times a day
at the track)... I corner a little faster than I should
(sometimes) on shorter tracks... I get 3-4 years out
of the fronts... I try to make it 4 years so I buy
my rears every 2 years and fronts every 4 years
Re: when was the last time you checked!! [Re: MR_P_BODY] #875271
12/09/10 12:26 PM
12/09/10 12:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I replace mine every year regardless.
Re: when was the last time you checked!! [Re: Al_Alguire] #875272
12/09/10 12:35 PM
12/09/10 12:35 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I was in the same boat with the same tires..they look great..I know they been on there 8 years anyhow.. I put a new set on last year just because........................I feel better now.
Re: when was the last time you checked!! [Re: fury62] #875273
12/09/10 01:17 PM
12/09/10 01:17 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
always play it safe...only you know the abuse they take and the rubber subjected to UV rays..
Re: when was the last time you checked!! [Re: fury62] #875274
12/09/10 01:56 PM
12/09/10 01:56 PM
organ
maximum entropy Offline
organ
well, you got me thinking. mine are going on ten years old, but they've had a very easy life. eighth mile, and when they're not racing, they're in a dark climate controlled garage with no weight on them. they look brand new.
Re: when was the last time you checked!! [Re: maximum entropy] #875275
12/09/10 04:28 PM
12/09/10 04:28 PM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
I replace the fronts every year and the rears every 12-15 passes. Kind of expensive but want to be certain I have no tire issues! Keep the old fronts around incase you puncture one at the track like I did this year. Allowed me to win the championship!
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: when was the last time you checked!! [Re: W8n2DustU] #875276
12/09/10 06:45 PM
12/09/10 06:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Rule of for most tire mfg's is 8 years ( a lot of variables here ). I change mine out after 5. If I were running around 150, I'd roll fresh rubber every year.
Fastest 300
