better short block for power ?340/360 with std stroke
#873861
12/07/10 08:40 PM
12/07/10 08:40 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
what is a better base line std stock short block for power with 11 1/2 to 1 pistons i havent done the machine work on my 360 w5 motor and was thinking would a 340 make more hp and be just as strong ??? thanks guys ! mopar or no car ! i havent got my pistons yet im willing to buy a block and crank
Re: better short block for power ?340/360 with std stroke
[Re: RAY1969CARS]
#873863
12/07/10 09:20 PM
12/07/10 09:20 PM
Quicktree
thats pretty much what I run with indy 360-1 heads. I doubt a 340 would make any more power at the same cubes and set up
hey I'll give yo $100 for those valve covers
[Re: RAY1969CARS]
#873865
12/07/10 10:45 PM
12/07/10 10:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
340 with its bigger bore... if you were buying a crank you could stroke it and end up with more CI... plus the bigger bore would unshroud the valve better
[Re: Quicktree]
#873866
12/07/10 11:51 PM
12/07/10 11:51 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
i payed 120 for them with the mp stud kit lolololol a steal ! my buddy bob at Mazzolini Racing
[Re: Cab_Burge]
#873868
12/08/10 10:26 AM
12/08/10 10:26 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
stock stroke short blocks, a 360 will make more power than a 340, because it is 6% larger in displacement.
now STOCK short blocks, I'd take a pre '73 340 over any 360, because with STOCK PISTONS, STOCK compression ratio will be much higher.
[Re: DaKuda]
#873870
12/08/10 11:15 AM
12/08/10 11:15 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
DON'T GET OFF TOPIC, HE IS BUYING PISTONS
The 340 and 360 block are basically the same before machined. The 340 has a larger bore but the 360 block will take the same bore. The 360 has larger main journals which means more speed in the bearing and more oil to lubricate. Some have done conversions with spacers and 340 aftermarket caps.
My understanding is a choice between 340 or 360 shortblock and order pistons and get machine work done. This was the original question. Not an arguement between 340 and 360 engines.
I had a 360 bored .100 over that made 378 cubic inches. We turned that engine 8,500 with W2 heads and aftermarket rods. Great combo. Most are not looking to spend a lot in valvetrain to turn the big RPM. Most would be reluctant to bore to 4.100" although it is a safe bore for a street engine if you sonic check the block first. .070 may be a safer choice which would get you a 4.070 bore giving you 372 CID. I like bore. The 340 came with more bore allowing more head flow and the fact that it came with 2.02 intake valves didn't hurt either LOL. It would be nice to get to a 340 main bearing and have a 4.100" bore with a 3.58 stroke. But, I'm guessing you are on a limited budget. Go with a 360 because they are cheaper. Look for 74' and older blocks if you want the larger bore. Later blocks may not be able to hold over 4.070". Just have the block sonic checked first before boring it is not expensive. Then bore to a safe bore and buy pistons. You will have a very inexpensive shortblock this way. Although cranks are incredibly cheap and there are a ton of 408 spinning assemblies available these days as mentioned.
Leon
